Need Help with routing on point to point T1 Cisco 1720
manish.shah.neo
We have a T1 line between Shenzhen and San Jose connected to Cisco 1720 router with following configuration:
Building configuration...
Current configuration : 1072 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname host
enable secret 5 <removed>
enable password <removed>
memory-size iomem 25
ip subnet-zero
no ip domain-lookup
interface FastEthernet0
ip address 10.15.15.2 255.255.255.0
speed auto
full-duplex
interface Serial0
bandwidth 1544
ip address 10.16.16.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.16.16.2
ip route 172.16.21.0 255.255.255.0 10.15.15.1
ip route 172.16.22.0 255.255.255.0 10.15.15.1
ip route 172.16.23.0 255.255.255.0 10.15.15.1
ip route 172.16.24.0 255.255.255.0 10.15.15.1
ip route 172.16.0.0 255.255.255.0 10.15.15.1
ip route 192.168.71.0 255.255.255.0 10.16.16.2
ip route 192.168.72.0 255.255.255.0 10.16.16.2
ip route 192.168.73.0 255.255.255.0 10.16.16.2
ip route 192.168.74.0 255.255.255.0 10.16.16.2
ip route 192.168.75.0 255.255.255.0 10.16.16.2
ip http server
snmp-server community <removed> RO
line con 0
line aux 0
line vty 0 4
password <removed>
login
no scheduler allocate
end
Our firewall has IP 10.15.15.1 255.255.255.0 and LAN traffic is routed through the firewall to Shenzhen subnet 192.168.X.X and vice versa and works fine. I can ping all subnets in Shenzhen.
Now I have installed another machine with IP 10.15.15.3 255.255.255.0 with this machine I can ping FastEthernet0 IP 10.15.15.2 and I can also ping Serial0 IP 10.16.16.1 but I cannot ping any subnets in Shenzhen.
What am I doing wrong? Any suggestion will be helpful. Thanks in advance.
-Manish
7 Replies 7
spremkumar
Level 9
Level 9
Hi Manish
Can you check whether you have a reverse route in your shenzen router for 10.15.15.0/24 block so that you can get the reply back when you ping from your pc.
Normally when you ping from your router the source ip taken may be ur wan interface ip and you have configured the same subnet (10.16.16.0/24) on both the ends.
I would suggest to change the subnet on the wan interface to a /30 instead of wasting or using /24 block out there.
regds
Thank you spremkumar, checked reverse route in Shenzhen router for 10.15.15.0/24 block and it is configured and I changed the subnet on the wan interface to a /30. Still no go :(.
Any help will be appreciated.
Hi MAnish,
Could you please paste the tracert command output from your source Network, that may help further.
Kind REgards,
Wilson Samuel
From Workstation
SanJose-> trace 192.168.73.1
Type escape sequence to escape
Send ICMP echos to 192.168.73.1, timeout is 2 seconds, maximum hops are 32
1 3ms 1ms 1ms 10.15.15.2
2 162ms 161ms 161ms 10.16.16.2 <-- Shezhen
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
31 * * *
32 * * *
From Router in San Jose
1720#trace 192.168.73.1
Tracing the route to 192.168.73.1
1 10.16.16.2 184 msec 188 msec 184 msec
2 192.168.73.1 188 msec * 184 msec
I feel in your firewall at Shezhen you haven't allowed the access for the LAN segment from San Jose which might be blocking the trace/icmp requests originating from san jose.
What kinda firewall device you are using out over there in the Shezhen ?
regds
Hi Manish,
I understand that the there is reverse route for the subnets in the szenchen router.I would request you to pls perform 2 tests and send it across to us.
1. Create a loopback ip in the Sanjose router- ip address 10.15.15.3/32(windows syetm ip)
Now trace to the destination with this source.
2. Create a loopback of this same IP in schenzen router and ping to the 192.168.73.1, with that source.
Pls note you will be able to run trace from sanjose router any how as the source IP that the packet from Sanjose router will take in this case is the serial IP.
Pls also paste the config of the scenzen router.
smothuku
Level 7
Level 7
Hi Manish ,
How is the new installed router is connected to Shenzhen and San Jose .
Satish
