Need to bundle two physical Layer 3 Links
mahesh_kv3
Hi all,
Iam having two FE ports in SPA-8XFE-TX " and the other end is WS-X6148A-RJ-45 ...so how can i bndle these ports in a single logical ports
Thanks in advance
Mahesh K V
mahmoodmkl
Level 7
Level 7
You can use a L3 etherchannel.
interface port-channel 1
no switchport
ip address 1.1.1.1 255.255.255.0
then under the physical interfaces
interface range fast0/1 - 2
no switchport
channel-group 1 mode on
the above config needs to be applied on both the devices.
Mahmood
Hi all,
Thanks for the response,but my SPA is not supporting the port-channel configs.Is there is any alternate to achieve the same.
Many Thanks In advance
Mahesh Vijayan
