Need to verify
wgranada1
Hi All
Sorry for the silly question, I problably should know the answer to this but just wanted to make sure. I have an application, RPC that for some reason isn't working. The funny thing is I can ping to the distant end server no problems, can trace route and telnet using ports 135,6001 and 6002. This tells me that I have IP connectivity and so as far as network wise goes all it is good correct? Also just a fyi I have a funky set up where the distant end subnet is split between 2 interfaces I have a static route going out g0/0.100 interface and I have a policy map that directs all the 180s subnet to route out the fa0/1 interface.
wgranada1
I know what the problem is...can anyone point me into the right directions on where I can read up on the "ip inspect" command the ones I've found so far are not helpfull.....thank you in advance
