Need Urgent Help
jerry_best
Hi guys i am facing problem in one of my router , i was trying to get the sh tech support for that router, i am getting following sh tech support format , i have seen first time can any body tell me wht is the problem and when i am getting such type of sh tech
Thanks in addvance
Jerry
Amex-Mum#sh tech-support
------------------ show version ------------------
------------------ show running-config ------------------
------------------ show stacks ------------------
------------------ show interfaces ------------------
------------------ show controllers ------------------
------------------ show file systems ------------------
------------------ dir nvram: ------------------
Directory of nvram:/
116 -rw- 9802 <no date> startup-config
117 ---- 27 <no date> private-config
118 -rw- 9802 <no date> underlying-config
1 -rw- 0 <no date> ifIndex-table
2 ---- 32 <no date> persistent-data
3 -rw- 1609 <no date> cerf_report
129016 bytes total (115039 bytes free)
------------------ show disk0: all ------------------
------------------ show bootflash: all ------------------
------------------ show environment last ------------------
------------------ show environment all ------------------
------------------ show memory statistics ------------------
------------------ show process memory ------------------
------------------ show process cpu ------------------
------------------ show process cpu history ------------------
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ show voice port ------------------
------------------ show dial-peer voice ------------------
------------------ show gateway ------------------
------------------ show call active voice ------------------
------------------ show call history voice last 50 ------------------
------------------ show region ------------------
------------------ show buffers ------------------
------------------ show diag ------------------
------------------ show c7200 ------------------
------------------ show pci hardware ------------------
------------------ show pci controller ------------------
Edison Ortiz
Let's see your current privilege level by typing show priv
What happens if you do a show version, do you get an output?
__
Edison.
i have priv that is not a problem ...yes sh version is coming..i have seen first time .
can anybody tell me
Thanks in Advance
Jerry,
There is a reason for the show priv command. We need to see what level you are at... You can still have access to a router but not be at the right priv level to show or execute commands.
Let's see the show version from this device.
__
Edison.
