neighbour not showing on HUB2, EIGRP
noob_route
Scenerio: There are 3 routers [2 hub (HQ-R1 & HQ-R2), 1 spoke router(B2)]. I had configured dmVPN and used EIGRP on all three routers for communication. But it is only showing neighbour with HQ-R1 and B2 only.
i want all three routers to be a neighbour.
here's my config:
HQ-R1
interface Tunnel1
description ***** TUNNEL-1 (PRIMARY) *****
ip address 172.16.10.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 1
delay 1000
tunnel source FastEthernet0/0
tunnel mode gre multipoint
tunnel key 1111
interface Tunnel2
description ***** TUNNEL-2 (SECONDARY) *****
ip address 3.3.3.3 255.255.255.0
no ip redirects
ip nhrp network-id 2
delay 2000
tunnel source FastEthernet1/1
tunnel key 2222
interface FastEthernet0/0
description ***** ISP-1 (PRIMARY) *****
ip address 1.1.1.3 255.255.255.0
duplex auto
speed auto
crypto map ISP1MAP
interface FastEthernet0/1
description ***** LAN-INTERFACE *****
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/1
description ***** ISP-2 (SECONDARY) *****
ip address 2.2.2.3 255.255.255.0
duplex auto
speed auto
crypto map ISP2MAP
router eigrp 2
network 3.3.3.0 0.0.0.255
network 172.16.10.0 0.0.0.255
network 192.168.10.0
HQ-R2
interface Tunnel3
description ***** TUNNEL-3 (PRIMARY) *****
ip address 200.200.200.1 255.255.255.0
no ip redirects
delay 3000
tunnel key 3333
interface Tunnel4
description ***** TUNNEL-4 (SECONDARY) *****
ip address 50.50.50.1 255.255.255.0
no ip redirects
delay 4000
tunnel key 4444
ip address 1.1.1.4 255.255.255.0
duplex auto
speed auto
crypto map ISP1MAP
description ***** LAN - INTERFACE *****
ip address 192.168.20.1 255.255.255.0
duplex auto
speed auto
ip address 2.2.2.4 255.255.255.0
duplex auto
speed auto
crypto map ISP2MAP
router eigrp 2
network 192.168.20.0
B2
interface Tunnel1
ip address 172.16.10.2 255.255.255.0
no ip redirects
ip nhrp map multicast 1.1.1.3
ip nhrp map 172.16.10.1 1.1.1.3
ip nhrp nhs 172.16.10.1
delay 1000
tunnel key 1111
interface Tunnel2
ip address 3.3.3.4 255.255.255.0
no ip redirects
ip nhrp map multicast 2.2.2.3
ip nhrp map 3.3.3.3 2.2.2.3
ip nhrp nhs 3.3.3.3
delay 2000
tunnel key 2222
interface Tunnel3
ip address 200.200.200.2 255.255.255.0
no ip redirects
ip nhrp map multicast 1.1.1.4
ip nhrp map 200.200.200.1 1.1.1.4
ip nhrp nhs 200.200.200.1
delay 3000
tunnel key 3333
interface Tunnel4
ip address 50.50.50.2 255.255.255.0
no ip redirects
ip nhrp map multicast 2.2.2.4
ip nhrp map 50.50.50.1 2.2.2.4
ip nhrp nhs 50.50.50.1
delay 4000
tunnel key 4444
ip address 1.1.1.2 255.255.255.0
duplex auto
speed auto
ip address 192.168.70.1 255.255.255.0
duplex auto
speed auto
ip address 2.2.2.2 255.255.255.0
duplex auto
speed auto
router eigrp 2
network 50.50.50.0 0.0.0.255
network 192.168.70.0
network 200.200.200.0
10 Replies 10
Hub1 have IP 2.2.2.3 but the Spoke is direct to 2.2.2.4, change the ip and try again.
noob_route
I didn't get it , what u want to say.?
dmvpn is all OK,
Problem is with EIGRP neighbour, they are not forming neighbourhood.
show dmvpn in Hub 1 and Hub 2,
can you share it
noob_route
old problem is solved but new arrived.
When i try to broadcast connected network on a router it shows, not on common subnet error on STANDBY AND SPOKE2
ERROR_MESSAGE : *Dec 3 12:43:47.675: EIGRP-IPv4(1): Neighbor 2.2.2.3 not on common subnet for FastEthernet0/0 no ip next-hop-self eigrp 1
HUB-STANDBY:
redundancy
ip tcp synwait-time 5
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp key FORISP1 address 1.1.1.4
crypto isakmp key FORISP2 address 2.2.2.4
crypto ipsec transform-set ISP1SET esp-3des esp-md5-hmac
crypto ipsec transform-set ISP2SET esp-3des esp-md5-hmac
crypto map ISP1MAP 1 ipsec-isakmp
set peer 1.1.1.4
set transform-set ISP1SET
match address 100
crypto map ISP2MAP 2 ipsec-isakmp
set peer 2.2.2.4
set transform-set ISP2SET
match address 100
interface Tunnel3
description ***STANDBY-PATH-1-***
no ip redirects
ip nhrp network-id 3
no ip split-horizon eigrp 1
delay 7000
tunnel key 3333
interface Tunnel4
description ***STANDBY-PATH-2-***
no ip redirects
ip nhrp network-id 4
delay 8000
tunnel key 4444
description ***ISP-1-PRIMARY***
ip address 1.1.1.1 255.255.255.0
duplex auto
speed auto
standby 2 ip 1.1.1.5
standby 2 preempt
standby 2 name wanisp1
crypto map ISP1MAP
description ***LAN-INTERFACE***
duplex auto
speed auto
standby 1 ip 192.168.10.5
standby 1 preempt
standby 1 name inlan
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
description ***ISP-2-SECONDARY***
ip address 2.2.2.1 255.255.255.0
duplex auto
speed auto
standby 3 ip 2.2.2.5
standby 3 preempt
standby 3 name wanisp2
crypto map ISP2MAP
router eigrp 1
network 1.1.1.0 0.0.0.255
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.30.0 255.255.255.0 1.1.1.4
ip route 192.168.30.0 255.255.255.0 2.2.2.4 10
ip route 192.168.50.0 255.255.255.0 192.168.10.4
access-list 100 permit ip 192.168.50.0 0.0.0.255 192.168.30.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
no cdp log mismatch duplex
control-plane
HUB-ACTIVE:
encr 3des
hash md5
encr 3des
hash md5
group 2
set peer 1.1.1.4
match address 100
set peer 2.2.2.4
match address 100
interface Tunnel1
description ***ACTIVE-PATH-1-****
no ip redirects
tunnel key 1111
interface Tunnel2
description ***ACTIVE-PATH-2-****
ip address 90.90.90.1 255.255.255.0
no ip redirects
delay 6000
tunnel key 2222
duplex auto
speed auto
standby 2 priority 110
standby 2 preempt
standby 2 name wlanisp1
crypto map ISP1MAP
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
standby 1 priority 110
standby 1 preempt
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
standby 3 priority 110
standby 3 preempt
crypto map ISP2MAP
router eigrp 1
network 90.90.90.0 0.0.0.255
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
SPOKE2:
redundancy
interface Tunnel1
no ip redirects
ip nhrp map 172.16.10.1 1.1.1.2
ip nhrp map multicast 1.1.1.2
tunnel key 1111
interface Tunnel2
ip address 90.90.90.2 255.255.255.0
no ip redirects
ip nhrp map 90.90.90.1 2.2.2.2
ip nhrp map multicast 2.2.2.2
ip nhrp nhs 90.90.90.1
delay 6000
tunnel key 2222
interface Tunnel3
no ip redirects
ip nhrp map 200.200.200.1 1.1.1.1
ip nhrp map multicast 1.1.1.1
delay 7000
tunnel key 3333
interface Tunnel4
no ip redirects
ip nhrp map 50.50.50.1 2.2.2.1
ip nhrp map multicast 2.2.2.1
delay 8000
tunnel key 4444
duplex auto
speed auto
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
router eigrp 1
network 2.2.2.0 0.0.0.255
no ip http server
nls resp-timeout 1
cpd cr-id 1
control-plane
can I know what was the solution for first Issue?
in Hub 2 "no next-hop-self" is not enter.
I was looking at the 'first' problem, it looks like on the HQ-R2 router, your EIGRP announced networks were incorrect. Using the EIGRP config below should work:
HQ-R2
router eigrp 2
--> no network 3.3.3.0 0.0.0.255
--> network 172.16.10.0 0.0.0.255
--> network 200.200.200.0
--> network 50.50.50.0 0.0.0.25
I guess you fixed that ?
Hello sir,
Will you look for "second" problem ?
I guess this is a lab and not a real network.
Check the interface connections:
duplex auto
speed auto
standby 2 preempt
crypto map ISP1MAP
FastEthernet0/0 is apparently expecting to see a 2.2.2.0/24 address configured. You must have reversed/swapped one of the interfaces.
Nope, i have shared the config,
Everything is correct from my side.
Now,
What willl be the solution ?
Hi friend
normally DMVPN with dual Hub have two approach
1- two hub two DMVPN cloud
2- two hub one DMVPN cloud
you use the first approach but friend two DMVPN cloud in spoke NOT in Hub
i.e.
Spoke have two tunnel (two DMVPN cloud) one for each Hub
and each hub has one tunnel (one DMVPN cloud).
there is case we have
one Hub with two DMVPN <- this case use when the Spoke use two ISP link for redundancy.
