USB to RJ45 Cable for Console?
tronic72
Does Cisco, or anyone else do a cable that will allow me to connect my USB only laptop to a console port on a Cisco device?
10 Replies 10
Edison Ortiz
Just do a google search for 'USB Serial' and you will find a lot of different models.
Here is one:
http://www.amazon.com/Keyspan-Speed-Serial-Adapter-USA-19HS/dp/B0000VYJRY
HTH,
__
Edison.
Thanks edison,
Was hoping there might be an All-in-one.....USB to RJ45 cable. I'm aware of the Serial to USB adapters
Thanks again.
This type of cable is made but they are few and far between.  If there is still interest in in them please let me know.
3.5 years later...! Use Bluetooth console devices.
I have one but trying to use it with putty to connect and it will not let me rj45 to usb
tronic72
I've found this product
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=281230
Can anyone confiirm this worked with Cisco devices?
Thanks.
It's similar to the product I pointed out before. Yes, it should work with Cisco devices.
HTH,
__
Edison.
simon
I decided to make one of my own - see http://www.get-console.com/shop/en/18-usb-to-serial-cables
Embedded USB to RS232 chip in the USB housing and has native drivers for OSX, Win7 and Win8. RJ45 end pinned out for Cisco serial console port.
Cheers
Simon
I know this is an old post but I just noticed it when searching for something related.
Check this out if this cable is needed. CablesAndKits nailed it:
https://www.cablesandkits.com/accessories/console-cables/usb-rj45-6ft/pro-9900/
Craig Haynie - CEO
CablesAndKits
OIKWAN Console Cable,USB Console Cable, USB to RJ45 Console Cable with FTDI chip Compatible with Cisco, Huawei,HP,Arista,Opengear,Aruba,Juniper Routers/Switches for Laptops in Windows, Mac, Linux https://www.amazon.com/dp/B075V1RGQK/ref=cm_sw_r_apan_glc_fabc_2QYCR9YC8717NNW2PGSV
