Netflow from Internet Router
fasteddye
We are having an issue getting netflow stats from our Internet Router.  It is a Cisco 2800 series router running BGP protocol.
Doing the sh ip flow export shows exports happening
  Exporting flows to 64.xx.xx.55 (2055)
  Exporting using source interface GigabitEthernet0/1
  Version 9 flow records, peer-as
  31212406 flows exported in 1078150 udp datagrams
  0 flows failed due to lack of export packet
  1 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
The Internet Router is at 64.xx.xx.1 and is exporting flows to 64.xx.xx.55.  We have the following on our ASA5520.
access-list OUTSIDE extended permit udp host 64.xx.xx.1 host 64.xx.xx.55 eq 2055
static (inside,outside) 64.xx.xx.55 10.xx.x.81 netmask 255.255.255.255
The 10.xx.xx.81 is the IP of server on inside of our network with netflow application running (Scrutinizer)
We never see any hits on the ACL.
Thanks.
Hello Ed,
yes what you would need is a static route for the scrutinizer ip address with next-hop = ASA outside interface
natting these packets is probably just a waste of resources on the firewall as private addresses are not routed on external interfaces of your border router with appropriate ACLs.
for example in my setup I have:
router#show run | inc flow-export
ip flow-export source Loopback0
ip flow-export version 5 origin-as
ip flow-export destination 172.20.25.10 2226
in my case the border router receives the route in OSPF but a static route could do the trick.
My ASA allows sending to UDP port 2226 from network side to inside with no NAT.
it can also be a question of order of operation: if NAT is perfomed first the ACL should look for the translated address and not the pre-NAT address
this could explain why number of matches is 0 for the ACL statement  and no packets reach the scrutinizer.
also check that the router is actually sending to the ASA by comparing
show ip arp 64.xx.xx.55
with MAC address in ASA outside interface they must match or the router is sending packets to somebody else!
Hope to help
Giuseppe
8 Replies 8
Jason Masker
Are you sure your NAT statement on the ASA is correct?  Typically for something like this, my ASA config would be:
object network obj-[INSIDE IP]
host [INSIDE IP]
nat (inside,outside) static [OUTSIDE IP]
Otherwise, your statement may be in a global format (not using objects) that is acceptable, but I would guess in that case that your outside & inside IPs might be swtiched. Is this host able to communicate out on that IP to other services?
Jason
Giuseppe Larosa
Hello Fasteddye,
may you post on BGP router
show ip route 64.xx.xx.55
Also I would suggest to use directly the private IP address of scrutinizer as the export destination adjust ip routing accordingly.
I don't see a good reason to NAT the netflow destination.
also take in consideration that export packets flow from outside to inside only the collector does not talk to the router
so NAT may not be triggered or the router is trying to send packets to the wrong next-hop
Hope to help
Giuseppe
Could you help explain further to not have to NAT this?
Here is the show ip route 64.xx.xx.55
Routing entry for 64.xx.xx.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Advertised by bgp 65535
  Routing Descriptor Blocks:
  • directly connected, via GigabitEthernet0/1
      Route metric is 0, traffic share count is 1
What would the route statement be to route to internal network?
If doing that I would not need NAT on firewall, maybe just an ACL?
-Ed
Hello Ed,
Hope to help
Giuseppe
Thanks for the recommendations.
I configured a static route on the internet router for 10.10.2.81 255.255.255.255 64.xx.xx.2. The 10.10.2.81 is inside address of netflow collector and the 64.xx.xx.2 is outside interface of ASA5520.
sh run | in flow-e
ip flow-export source GigabitEthernet0/1
ip flow-export version 9 peer-as
ip flow-export destination 10.10.2.81 2055
I have the following ACL in place on ASA5520 and it shows hits, access-list OUTSIDE extended permit udp host 64.xx.xx.1 host 10.10.2.81 eq 2055
I know see this in the log from ASA
5 Oct 22 2010 08:44:50 10.10.2.81 2055 Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src outside:64.xx.xx.1/50847 dst inside:10.10.2.81/2055 denied due to NAT reverse path failure
Not exactly sure what that means.
-Ed
Hello Ed,
so there is some progress
the ASA log message means that you need to find a way to tell it that that address 10.10.2.81 can be seen on outside interface
if you haven't already done you need to remove the nat rule that was present before in ASA configuration
Hope to help
Giuseppe
Well maybe...
I had removed the NAT rule that was in place before.
Then in my attempt to fix log message, I did the following.
What would adding this following do? I tried to add a Nat exempt (inside interface with any source and destination 10.10.xx.81)
access-list inside_nat0_outbound extended permit ip any 10.10.2.81 255.255.255.255
I added that and the log messages stopped happening and then I removed it and now I don’t see hits on the ACL anymore.
Hello Ed,
read the NAT chapter in ASA config guide
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/cfgnat.html
see section named bypassing NAT
Hope to help
Giuseppe
