Netflow ingress vs egress
Jerome C.
I have a Cisco router (2911). On the gi0/0, the router's network provider (WAN) is connected and on Gi0/1.618, it's my internal FW (and behind this FW, all my LAN server, clients..)
I'am able to monitor my bandwidth with PRTG but I would like to know, which protocol consumes the most bandwidth  from my LAN to the WAN. I configured the netflow but when I look at on my monitoring tool (prtg) the value that I see is very slow and I think this is not correct.
Here my configuration: on my router :
# ip flow-export destination 10.1.1.1
#  ip flow-export version 9
# ip flow-cache timeout active 1
# ip flow-cache timeout inactive 15
# ip flow-export source loopback0
# interface GigaEthernet 0/1.618
# ip flow ingress
Is it correct ?
BR
Jerome
Julio E. Moisa
Hi Jerome,
Your config looks fine, now are you passing a lot of traffic? what software are you using to monitor the traffic?
Now take in consideration these values:
# ip flow-cache timeout active 1 <---- in minutes
# ip flow-cache timeout inactive 15  <---- in seconds, so inactive entries will be removed in 15 seconds.
Try to increase these values.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
in addition to Julio's post, the recommended values by Paessler actually are:
ip flow-cache timeout active 5
ip flow-cache timeout inactive 10
Also, you might want to specify a UDP port number (make sure to configure the same port in the NETFLOW SPECIFIC SETTINGS/Receive NetFlow Packets on UDP Port in your Sensor Settings), e.g.:
ip flow-export destination 10.1.1.1 9991
