Network Performance Issues when upgraded to IOS 12.4.24.T5 on 881W
jaesposito
All,
I'm really at a loss.  I have a Cisco 881W router.  It has historically run IOS 12.4 (20.T3) without issue.  I recently upgraded the IOS to version 12.4 (24.T5).  Once I made that upgrade, my ability to fully throttle my downstream bandwidth became seriously limited and variable going from a steady 6Mbps to an unreliable 2-3Mbps.  No other changes were made to my environment.  The degredation in performance was so bad that my AppleTV would no longer stream Netflix or YouTube.
I downgraded back to the original IOS 12.4 (20.T3) and the downstream bandwidth and variability issues disappeared.  As well, my ability to stream movies or videos with my AppleTV on Netflix or YouTube returned without issue.
I wonder if upgrading to IOS 12.4.24.T5 enabled some new commands that I'm not catching or there is something else at play that I'm totally missing.  If this sounds familiar to anybody OR if you have some suggestions on how I might be able to begin troubleshooting this problem, I would greatly appreciate it.  Attached is a copy of the configuration of my 881W.
I'm open to any and all suggestions as I'm really stuck.  I'd love to upgrade the IOS to the newest version, but cant seem to get past this reproducable problem.
Thank you all for the help!  This forum is great!
James E
10 Replies 10
paolo bevilacqua
Try removing inspect and zone firewall. They are unecessary anyway.
Forgive my elementary question.  If I remove the inspect and zone firewall, then what will be left in my configuration to provide me with firewall protection?  My Cisco skills were much sharper 7 years ago when ACLs were the only way to apply firewall rules.  I know little about zone firewall configurations.
Thanks very much!
James E
With NAT, you don't need firewall. No packets from outside can reach inside, unless the connection is initiated from inside.
Got it.
Any suggestions on how I might be able to narrow down the problem if it in fact ends up being a problem with the zones or the inspection?
Thanks!
James
I have an 850 modem loaded with them.  When I took the inspection rules and firewall rules the speed went faster.
What risks do you run by removing the INSPECT rules?
Any thoughts on my INSPECT and FIREWALL rules pasted below?
I'm running this configuration at home with a bunch of consumer devices behind it.  Nothing sophisticated.
James E
parameter-map type inspect global
log dropped-packets enable
license udi pid CISCO881W-GN-A-K9 sn FTX132880G9
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-protocol-http
class class-default
  drop
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface Null0
no ip unreachables
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
zone-member security in-zone
ip tcp adjust-mss 1412
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
zone-member security out-zone
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-top-talkers
top 12
sort-by bytes
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
logging esm config
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
dialer-list 1 protocol ip permit
no cdp run
As mentioned above. There is no risk whatsoever.
Note also. All IP commands under Fa4 are unnecessy as no IP is enabled there.
ip mtu 1452
should be instead
mtu 1491
if you're not using flow, remove it as well.
basically you have a GUI-polluted config and need to clean it up for optimal results.
Paolo - Thank you.  What other clean up suggestions do you recommend?
I'm leaving on NetFlow as I periodically check the data.
THank you for the help!
James E
Leave flow on one interface only.
Clean it up then repost.
Ok.  I will do that tonight (around 9pm EST) and repost the config.
James
