Network resilience
raoul2341
Hello everyone
Could someone please help with the following query.
We are trying to implement a change on our network (please see the attached network diagram).
Please note that the links in red are new links that needs to be implemented. The 2 sites are part of the same logical network and we use different subnets  on the 2 sites and all the vlan interfaces are defined on the layer 3 switch on site A and ALL traffic bound for the WAN goes via Firewall 1 and Router 1 using static routes.
We are in the process of adding another link the the WAN as seen on the diagram. The 2 new requirements are:
1. We want traffic from Vlan 30 and 40 bound for the private network to go via the new link (Firewall B and Router B)
2. In case of failure of Router A or Router B, we want all traffic bound for the private network to go via the Router that is up.
Any help implementing these requirements is greatly appreciated.
Raoul.
    You might consider to run a routing protocol between 2 sites(all devices) and then adjust path cost on 2 coreswitches to prefer WAN link. In case WAN link's down the coreswitch should use fiber(backdoor) instead.
HTH,
Toshi
Thanks Toshi for your reply. I knew that I needed to implement a routing protocol between 2 sites but I need help on where and how to implement.
Raoul
   Okay you need to do as follows:
Lets say OSPF is what I want.
Both sites
1. L3 switch(including fiber(backdoor) , ASA , WAN Router  running OSPF.
2. L3 switch will see network(vlan) of other sites via 2 possible paths. It should use fiber first.
3. You just modify cost on fiber link to be worst(65535) than a link(summary cost) connected to Firewall.
HTH,
Toshi
