new 2811 config
thinakraj
we are planning to migrate 3 E1 circuits from our 6506 (running CATOS) to a new 2811. I have configured the router but have some questions regarding how I should set up the fax. I have attached 2 config files, one for our existing 2811 (bne-vg-2811). This router currently has 2 ISDN lines attached. The 2nd attachment (bne-vg-2811-fax) is the config for the new router. This also has 2 ISDN circuits but also has a connection to our fax server. The fax has 8 channels.
I am not sure is I have configured interface serial 0/1/0:15 correctly. Do I set it up the same as the ISDN circuits? The same applies to voice-port 0/1/0:15. I'm not sure if this is setup correctly.
Could you please advise.
Thina.
paolo bevilacqua
I suppose you are the end user ?
I recommend you locate an UC certified cisco partner, or reputable consultant to complete the configuration and testing.
They can also recommend an IP based fax solution considering the ISR router cad do fax termination beside voice.
