new cisco 887va Router installation
mod0108537733
Dear all
I'll install a cisco 887va-k9 router next week. would you please tell me how to install it to act as  ADSL modem to my LAN  regarding blow informations:
adsl
pppoe
vpi/vci 0/35
username U
password P
kind regards
Mahmoud
18 Replies 18
I checked with my ISP and find that
-my public range is working fine
-and I should use RFC 1483 Routed LLC
so now I have this info
vpi/vci:  8/35
For lan as they said
gateway: 84.x.x.x (public ip)
subnet: 255.255.255.240
Internet connection
Login Type:RFC 1483 Routed
Multiplexing:LLC
ADSL Modulation : Multimode
IP Address:10.84.44.226 (mine)
Subnet Mask: 255.255.255.252
Default Gateway: 10.84.44.225(isp)
how i can configure that on cisco 887va where i tried this configuration on adsl modem (tplink) it works fine
I checked with my ISP and found that my real ip pool is ok .
but i have new info :
vpi/vci:  8/35
Internet connection
RFC 1483 Routed
Multiplexing:LLC
and for my lan (ISP said to use my real ip  in lan)
gateway: 84.x.x.x
I tried with ADSL modem (tplink) it worked fine
can you help please to configure cisco 887va
so many thanks to you shanil
merci Monsieur Shanil
s il vous plait si j ai besoin de faire un vpn (avec IPsec) de mon pc à ma maison vers ma societe (qui a un routeur Cisco 887VA-k9) ,
-j ai une connexion internet adsl;
-j ai une Adress public de ma societé ;
la procédure en detail pour faire ça ??.
que ce que j ai besoin pour le faire.
Merci
please if i need to make a vpn (with IPsec) from my pc to my house to my company (which has a Cisco 887VA-k9 router),
-I have an adsl internet connection;
-I have a public address of my company;
the procedure in detail to do that ??.
than what I need to do it.
Thank you
