NEW CISCO ROUTER 4321 SETUP
21 Replies 21
marce1000
 - Please  , elaborate on your question ,what is your specific-problem-need , what did you try , what does not work, etc...
 M.
The problem is, my router is very new from the shop, when i try to enter
configuration mode by using putty software, it doesn't allow me to do so.
The only message that is displayed is " CONFIG_P: configured
programmatically by process pnp agent discovery from console as vty0". When
I press "enter" button the same message repeats again and again. What
should I do then?
@menasmathematics wrote:
configured programmatically by process pnp agent discovery from console as vty0
What firmware is the router loaded with?  Autonomous IOS or SD-WAN?
The phrase above sounds like the router was purchased with SD-WAN image.  Converting it from SD-WAN to Autonomous IOS is possible but it is a major pain for someone who is not familiar.
it is   Autonomous IOS
Can you help me please..@Leo Laohoo
Go to enable mode and then post the complete output to the following commands:
  1. sh version
  2. dir
IMPORTANT:  DO NOT post screenshots.
The problem is, It doesn't allow me to write any command. See the attached screenshot and advice please
You.  Posted.  Screenshots.
AM sorry. But I wanted to let you know what exactly hinders me from proceeding.
Help me please
Ok, last chance.
  1. Power down the router.
  2. Connect the console cable.
  3. Power up the router.
  4. Post the entire boot-up of the router.
WARNINGDO NOT post screenshots.
It started booting but at the end it displayed "failed to initialize nvram" and "failed to initialize backup nvram"
after few minutes it then displayed "SIM_ACQUISITION_TIMEOUT: [Cellular0/2/0]: SIM s lot 0 Acquisition Timer timeout !!"
It started booting but at the end it displayed "failed to initialize NV ram" and "failed to initialize backup NV ram"
