New ISRG2 2921 restarts very often.
grzegorzniecka
Dear all,
from todays morning my 2921 is restarting about one time per two hours:
uptime is 1 minute
System returned to ROM by bus error at PC 0x23A49808, address 0x0 at 15:45:07 CET Tue Apr 10 2012
System restarted at 15:46:39 CET Tue Apr 10 2012
System image file is "flash0:c2900-universalk9-mz.SPA.152-2.T.bin"
Last reload type: Normal Reload
Last reload reason: bus error at PC 0x23A49808, address 0x0
#sh region
Region Manager:
0x21000B78  0x26868463    92698860  IText  R/O    main:text
#sh context
System was restarted by bus error at PC 0x23A49808, address 0x0 at 15:45:07 CET Tue Apr 10 2012
C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T, RELEASE SOFTWARE (fc1)
Compiled Tue 15-Nov-11 22:10 by prod_rel_team
Image text-base: 0x21002A78, data-base: 0x2686C1A0
Stack trace from system failure:
FP: 0x2B76A4F0, RA: 0x23A49808
FP: 0x2B76A520, RA: 0x23A540A8
FP: 0x2B76A578, RA: 0x23A5AEC8
FP: 0x2B76A598, RA: 0x22ACDFA4
FP: 0x2B76A5E8, RA: 0x211966A0
FP: 0x2B76A628, RA: 0x21198374
FP: 0x2B76A6A0, RA: 0x211994A4
FP: 0x2B76A6D8, RA: 0x211729F0
Fault History Buffer:
Signal = 10, Code = 0xC, Uptime 02:20:07
$0 : 00000000, AT : 00000000, v0 : 00000001, v1 : 00000003
a0 : 00000001, a1 : 00000003, a2 : 00000001, a3 : 2A1C0000
t0 : 0000FFFF, t1 : 000001B8, t2 : 00000000, t3 : 00000000
t4 : 23A49660, t5 : 00000001, t6 : 00000001, t7 : 00000001
s0 : 00000000, s1 : 2A1C0000, s2 : 2B270600, s3 : 33A5C008
s4 : 0000001E, s5 : 00000000, s6 : 2A1C0000, s7 : 0000001F
t8 : 00000000, t9 : 00000005, k0 : 00000000, k1 : 00000000
gp : 2A6CB220, sp : 2B76A4F0, s8 : 2BCD2A0C, ra : 23A49694
EPC : 23A49808, SREG : 500099E3, Cause : 0000000C
Error EPC : 80413D20, BadVaddr : 00000000
TEXT_START : 0x21002A78
DATA_START : 0x2686C1A0
What this can be the issue?
paolo bevilacqua
Typically bug crash.
Cisco has removed he ability to look for bugs using the stack trace, so either you contact the TAC, or blindly try a different IOS version.
gephelps
This is a software bug. You should upgrade to 15.2(2)T1 or later for CSCtw67283
