new to cloned virtual access interfaces
tiwang
Level 4
Level 4
hi out there
We are migrating our vpn deployment from god old cryptomaps to virtual access cloned interfaces - we are still in "learning" phase where we deploy ezvpn-clients which connects to a central server. we have currently two VRF's defined with a internet vrf where the clients connects to and a service vrf where the clients are forwarede to the needed services. When the routers are connected the routingtable in that service-vrf look like this:
Gateway of last resort is not set
     10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
S       10.120.3.1/32 [1/0] via 0.0.0.0, Virtual-Access4
S       10.120.3.0/24 [1/0] via 0.0.0.0, Virtual-Access4
S       10.120.1.1/32 [1/0] via 0.0.0.0, Virtual-Access3
S       10.120.1.0/24 [1/0] via 0.0.0.0, Virtual-Access3
S       10.120.4.0/24 [1/0] via 0.0.0.0, Virtual-Access2
S       10.120.4.1/32 [1/0] via 0.0.0.0, Virtual-Access2
Is this as expected ? It bothers me a bit that the next hop is noted as 0.0.0.0 Each ezvpn client has a loopback interface which is the inside of the client (which is assigned a 10.120.x.1/32 adresse) and nat-pool (10.120.x.0/24)  through which the internal clients access the published service through the VPNServer.
tiwang
Level 4
Level 4
hi again
Really no-one out there seen a similar scenario? I just need verification that it looks as expected since I havent got anything to compare it with..
best regards /ti
