POE Option on 880 Series
eagletec1
Hi all,
Does anyone know if the two listed POE switch ports on the 880 series routers are active out of the box (default) or is configuration or extra parts required as internet pictures appear to show what looks like a power connector new to the POE ports?
Cheers Louise
8 Replies 8
Sandeep Choudhary
CISCO881W and C881W Comparison
Model
Fan Configuration
Power over Ethernet (PoE) Configuration
Memory Configuration
Antenna Configuration
CISCO881W
One fan
2-port PoE support, through separate PoE power adaptor
Field-upgradable option
Default: 256 MB
Maximum: 768 MB
External
C881W
Fanless
2-port PoE support; no separate PoE adaptor needed
Factory option only
Default: 512 MB
Maximum: 1024MB
Embedded
may be this the answer of you question ?
Please rate if it helps
Thanks Sandeep for your reply but unfortunately not, the units I'm looking at are 888-K9. The spec does say factory option POE but the routers have power plug next to the switch FE" 0 and 1" ports so it appears to me an external power supply will be required but the documentation seems to contradict that hence the reason for my question. Has anyone got a POE device running of a 888-K9 router?
Louise
Router desc:
  • Four 10/100 Mbps fast Ethernet managed switch ports with optional Power over Ethernet (PoE) on two switch ports .
this is wahat i can see on cisco website.
Ya I've seen that too, it's all very vague. I'm thinking that either an external PSU is required as POE is normally 48v and the router is powered by a 12v external PSU or the power connector is for a second POE device so as to make all 4 switch ports POE.
Louise
Leo Laohoo
If you want to power up to four ports 15.4 PoE then it would have to be the 890 with a PoE daughter module and a separate power brick.
Router#sh pow inline
PowerSupply   SlotNum.   Maximum   Allocated       Status
EXT-PS           0        80.000     0.000          PS GOOD
Interface   Config   Device   Powered    PowerAllocated
Fa0         auto     Unknown  Off        0.000 Watts
Fa1         auto     Unknown  Off        0.000 Watts
Fa2         auto     Unknown  Off        0.000 Watts
Fa3         auto     Unknown  Off        0.000 Watts
Router#sh inv
NAME: "891", DESCR: "891 chassis, Hw Serial#: FHK150277V6, Hw Revision: 1.0"
PID: CISCO891W-AGN-N-K9, VID: V01, SN: FHK1502BANG
NAME: "ESW Power Daughter Card", DESCR: "4-Port ESW Power Daughter Card"
PID: 800-IL-PM-4       , VID: V01 , SN: FOC1436BLAH
Thanks, but does that mean the 2 factory options ports (FE 0 &1) on the 888-K9 are already powered or also need an external power supply?
Louise
Not sure about the 888 as I haven't used it.  However, in a majority of cases, you still need a PoE daughter card and a PoE power brick if the PoE option is ordered separately.
Cheers, it's just not very clear what is required. I guess I'll just order and play.
