NewBie - how to connect to new network
winanjaya
Hi The Expert,
I am very new with this,
I have 4 branches on
HO is on 172.16.1.0/24
branch A is on 172.16.2.0/24
branch B is on 172.16.3.0/24
branch C is on 172.16.4.0/24
branch D is on 172.16.5.0/24
they are connected with frame relay ..
currently, one of my customer also want to connect into our network .. they are on network 192.168.210.0/24, I don't know how to configure my CISCO to connect to their network..
could any body please help
thanks a lot in advance
Winanjaya
8 Replies 8
imnilesh
Hi;
As ur requirment is to connect outside network to ur network. so Somehow you need to connect them to ur network but dont want to give access all the network.
so you can NAT and allow only specific server and ports to be accessible from there network.
Nil
kamal-learn
Level 4
Level 4
hi
not enough information about what you want to do !!!
so connect the new customer as you did for branch A!
(do you want to grant this customer access to the all network? are you using public network (VPN through internet, or a private network FR/...?)
please do clarify more
Yes, I am using Frame Relay, we want to access their intranet web server and also the database..
any idea?
TIA & Regards
Winanjaya
Hi The Expert,
Currently I have better progress..now I can ping to my customer's network on 192.168.210.0/24 ..
I tried to ping their intranet web server on 192.168.210.100 .. it resolved but why I am unable to see their web page? .. please help
C:\>tracert -h 5 192.168.210.100
Tracing route to ADWEBSERVER [192.168.210.100]
over a maximum of 5 hops:
1 <10 ms <10 ms <10 ms router-ho.lippogeneral.com [172.16.1.2]
2 47 ms 78 ms 63 ms 172.16.254.26
3 63 ms 78 ms 63 ms ADWEBSERVER [192.168.210.100]
C:\>ping 192.168.210.100
Pinging 192.168.210.100 with 32 bytes of data:
Reply from 192.168.210.100: bytes=32 time=63ms TTL=127
Winanjaya
hi
i think you have a dns problem, since you are able to ping the server but you can not resolve a domain name so from your internet explorer just put the address of the web server and you could see the web page .
(use the host file in your server or PC to set up the resolution of the domain name)
when you open the host file you will see an example of how to configure it. this solution is temporary until the complete resolution of your dns problem.
do rate if it does clarify
I am using IP address from my IE .. but it's still not working .. ;<(
do post the config of your router, if possible both routers may be over there some acls that are blocking traffic!!!
on my site:
Ro_kwc>en
Password:
Ro_kwc#sh ip route
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 172.16.1.5 to network 0.0.0.0
S 192.168.210.0/24 [1/0] via 172.16.254.26
172.16.0.0/16 is variably subnetted, 10 subnets, 2 masks
C 172.16.254.8/30 is directly connected, Serial0/0.6
C 172.16.254.12/30 is directly connected, Serial0/0.3
C 172.16.254.20/30 is directly connected, Serial0/0.8
C 172.16.254.24/30 is directly connected, Serial0/0.4
C 172.16.254.28/30 is directly connected, Serial0/0.2
D 172.16.8.0/24 [90/1764352] via 172.16.254.22, 04:15:33, Serial0/0.8
D 172.16.6.0/24 [90/1764352] via 172.16.254.10, 02:18:16, Serial0/0.6
C 172.16.1.0/24 is directly connected, FastEthernet0/0
D 172.16.2.0/24 [90/1764352] via 172.16.254.30, 04:15:40, Serial0/0.2
D 172.16.3.0/24 [90/1764352] via 172.16.254.14, 04:15:29, Serial0/0.3
S* 0.0.0.0/0 [1/0] via 172.16.1.5
C 198.168.0.0/20 is directly connected, FastEthernet0/0
Ro_kwc#
on my Customer's site:
Ro_Admedika>en
Password:
Ro_Admedika#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
Gateway of last resort is 172.16.254.25 to network 0.0.0.0
C 192.168.210.0/24 is directly connected, FastEthernet0/0
D 172.16.254.8/30 [90/2681856] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.254.12/30 [90/2681856] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.254.20/30 [90/2681856] via 172.16.254.25, 01:08:03, Serial0/0.1
C 172.16.254.24/30 is directly connected, Serial0/0.1
D 172.16.254.28/30 [90/2681856] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.8.0/24 [90/2684416] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.6.0/24 [90/2684416] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.1.0/24 [90/2172416] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.2.0/24 [90/2684416] via 172.16.254.25, 01:08:03, Serial0/0.1
D 172.16.3.0/24 [90/2684416] via 172.16.254.25, 01:08:03, Serial0/0.1
S* 0.0.0.0/0 [1/0] via 172.16.254.25
D 198.168.0.0/20 [90/2172416] via 172.16.254.25, 01:08:04, Serial0/0.1
Ro_Admedika#
