Newbie to VPN - Cisco Router to pfSense IPSec problems
Brett Tesdall
Hi, everyone,
I'm still in the process of learning about Cisco, but I'm now tasked with a problem that I'm stuck on and up against a time limit to fix.
At our home office, we have a pfSense box providing IPSec tunnels to some remote locations and these are working fine.  We're now setting up a new remote office and we're wanting to put a Cisco 1921 there as the IPSec endpoint because a couple of months from now, we hope to have this location added to our MPLS and the Cisco should be able to handle that.  Temporarily, we'll be having a cable modem connection to provide Internet service and want to VPN back to the home office as well as provide general Internet services for the office people.
Right now, my connection to the remote office LAN is on G0/0 of the 1921.  It has an IP of 10.23.10.1 and is providing DHCP services to the LAN.  I have plugged a computer into G0/0 and confirmed DHCP is working.  The 1921 is currently in our home office while I set it up, so for testing, I plugged a cable into G0/1 that was for an outside connection to the Internet.  In this configuration, I was able to confirm that my test computer could get out to the internet through the 1921 after I added a default static route.  So, at this point, everything seemed to be working fine.
Then I began to working on the VPN between the Cisco and pfSense using this article as a guide:  https://doc.pfsense.org/index.php/IPsec_between_pfSense_and_Cisco_IOS   For the most part this worked, although I made an error in the Phase 2 portion, but thought I had it fixed.  However, while the tunnel does appear to be established, no traffic is passing.  Also, no Internet traffic is passing either, so this is clearly not doing a split-tunnel.
This is what the debug for IPSec is showing:
*Feb 18 15:56:09.987: IPSEC(validate_proposal_request): proposal part #1
*Feb 18 15:56:09.987: IPSEC(validate_proposal_request): proposal part #1,
  (key eng. msg.) INBOUND local= 205.237.121.4:0, remote= 205.237.121.1:0,
    local_proxy= 10.23.0.0/255.255.240.0/256/0,
    remote_proxy= 10.0.0.0/255.248.0.0/256/0,
    protocol= ESP, transform= NONE  (Tunnel),
    lifedur= 0s and 0kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x0
*Feb 18 15:56:09.987: Crypto mapdb : proxy_match
        src addr     : 10.23.0.0
        dst addr     : 10.0.0.0
        protocol     : 0
        src port     : 0
        dst port     : 0
*Feb 18 15:56:10.039: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Feb 18 15:56:10.039: Crypto mapdb : proxy_match
        dst addr     : 10.0.0.0
        protocol     : 256
        src port     : 0
        dst port     : 0
*Feb 18 15:56:10.039: IPSEC(crypto_ipsec_create_ipsec_sas): Map found PFSVPN
*Feb 18 15:56:10.039: IPSEC(create_sa): sa created,
  (sa) sa_dest= 205.237.121.4, sa_proto= 50,
    sa_spi= 0xDB886A86(3683150470),
    sa_trans= esp-3des esp-sha-hmac , sa_conn_id= 2007
    sa_lifetime(k/sec)= (4608000/3600)
  (sa) sa_dest= 205.237.121.1, sa_proto= 50,
    sa_spi= 0x73DE9E8(121498088),
    sa_trans= esp-3des esp-sha-hmac , sa_conn_id= 2008
*Feb 18 15:56:10.043: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Feb 18 15:56:10.043: IPSEC(key_engine_enable_outbound): rec'd enable notify from ISAKMP
*Feb 18 15:56:10.043: IPSEC: Expand action denied, notify RP
So, at this point, I'm a bit stuck as to what's wrong.  First, I need to get the VPN working and passing traffic.  Secondly, I need to configure this as a split-tunnel so only traffic destined for the home office goes over the VPN and everything destined for the Internet does not.
Any suggestions?  I'm attaching the config for the 1921.
Thanks!
Brett
P.S.  Just one note about the config....At our home office, we have multiple subnets in the 10.x.x.x ranges.  We want traffic that is destined for any of them to traverse the VPN.
19 Replies 19
I've re-checked pfSense and the Cisco router.  Found that my wildcard masks didn't quite match up.  The network at the home office is 10.0.0.0/13, but I was doing the equivalent of a 10.0.0.0/8 on the Cisco.  I fixed this, but still no traffic passing and the debugging still looks the same.
Does anyone have some familiarity with pfSense's IPSec?
Hi Brett,
If you have changed on the router on the ACL 100, from 10.0.0.0/8 to 10.0.0.0/13, then you also have to change it on ACL 101 as well for deny line.
no access-list 101 deny   ip 10.23.10.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 deny  ip 10.23.10.0 0.0.0.255 10.0.0.0 0.7.255.255
Let me know, if this helps.
Rizwan Rafeek.
SUCCESS!
Looks like after I fixed the wildcard mask from 0.255.255.255 to 0.7.255.255, the tunnel was configured properly.  We kicked it and restarted it and traffic began to flow!
I've corrected the access-list 101 to the right wildcard mask so everything should be right now.
Thanks for all the help!
Hi, Rizwan,
I made that change and found another error that the access-list 101 wasn't associated with the crypto map PFSVPN.  It was still looking for access-list 100.  I changed that and also what you suggested, but seem to be back where I started from.
Getting this on the IPSec debug:
*Feb 18 19:03:34.531: IPSEC(validate_proposal_request): proposal part #1
*Feb 18 19:03:34.531: IPSEC(validate_proposal_request): proposal part #1,
    local_proxy= 10.23.10.0/255.255.255.0/256/0,
*Feb 18 19:03:34.531: Crypto mapdb : proxy_match
        src addr     : 10.23.10.0
        dst addr     : 10.0.0.0
        protocol     : 0
        src port     : 0
        dst port     : 0
*Feb 18 19:03:34.583: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Feb 18 19:03:34.583: Crypto mapdb : proxy_match
        dst addr     : 10.0.0.0
        protocol     : 256
        src port     : 0
        dst port     : 0
*Feb 18 19:03:34.583: IPSEC(crypto_ipsec_create_ipsec_sas): Map found PFSVPN
*Feb 18 19:03:34.583: IPSEC(create_sa): sa created,
    sa_spi= 0x3B2EF298(992932504),
    sa_trans= esp-3des esp-sha-hmac , sa_conn_id= 2009
    sa_spi= 0x8AEC545(145671493),
    sa_trans= esp-3des esp-sha-hmac , sa_conn_id= 2010
*Feb 18 19:03:34.587: IPSEC(key_engine): got a queue event with 1 KMI message(s)
*Feb 18 19:03:34.587: IPSEC(key_engine_enable_outbound): rec'd enable notify from ISAKMP
*Feb 18 19:03:34.587: IPSEC: Expand action denied, notify RP
Trying to ping from a machine on the LAN side stops at the 10.23.10.1 address, the IP of G0/0.  Error says "Destination host unreachable."
