[newbie] Trouble connecting Cisco Router to ISP Router/Modem
mirnesc92
Hey Guys,
I have a local area network setup on a Cisco 891-W router and Catalyst 3750 switch, that I am trying to connect to the public internet. In order to do that I understand I have to connect my Cisco router to my Verizon ISP router/modem.
I tried following this Cisco How To Guide but still can't seem to connect. I can't seem to figure out where I went wrong here.
The Cisco router is connected to the Verizon ISP router on Gi0; and the Cisco switch on Fa8.
This is my current running-configuration of the Cisco router.
R1(config)#do show run
Building configuration...
Current configuration : 4681 bytes
! Last configuration change at 17:15:14 UTC Tue Sep 29 2015 by admin
! NVRAM config last updated at 16:44:29 UTC Tue Sep 29 2015 by admin
version 15.1
service password-encryption
hostname R1
boot-start-marker
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
enable secret 5 [removed].
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip source-route
ip dhcp excluded-address 196.1.10.2 196.1.10.200
ip dhcp excluded-address 196.1.20.2 196.1.20.200
ip dhcp excluded-address 196.1.30.2 196.1.30.200
ip dhcp excluded-address 196.1.40.2 196.1.40.200
ip dhcp excluded-address 196.1.50.2 196.1.50.200
ip dhcp excluded-address 196.1.60.2 196.1.60.200
ip dhcp excluded-address 196.1.66.2 196.1.66.200
ip dhcp excluded-address 196.1.77.2 196.1.77.200
ip dhcp pool vlan10
 network 196.1.10.0 255.255.255.0
 default-router 196.1.10.1
ip dhcp pool vlan20
 network 196.1.20.0 255.255.255.0
 default-router 196.1.20.1
ip dhcp pool vlan30
 network 196.1.30.0 255.255.255.0
 default-router 196.1.30.1
ip dhcp pool vlan40
 network 196.1.40.0 255.255.255.0
 default-router 196.1.40.1
ip dhcp pool vlan50
 network 196.1.50.0 255.255.255.0
 default-router 196.1.50.1
ip dhcp pool vlan60
 network 196.1.60.0 255.255.255.0
 default-router 196.1.60.1
ip dhcp pool vlan66
 network 196.1.66.0 255.255.255.0
 default-router 196.1.66.1
ip dhcp pool vlan77
 network 196.1.77.0 255.255.255.0
 default-router 196.1.77.1
ip cef
ip domain name mydomain.net
no ipv6 cef
license udi pid CISCO891W-AGN-A-K9 sn [removed]
username admin password 7 [removed]
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 no ip address
 ip nat inside
 ip virtual-reassembly in
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
interface FastEthernet8.10
 encapsulation dot1Q 10
 ip address 196.1.10.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.20
 encapsulation dot1Q 20
 ip address 196.1.20.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.30
 encapsulation dot1Q 30
 ip address 196.1.30.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.40
 encapsulation dot1Q 40
 ip address 196.1.40.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.50
 encapsulation dot1Q 50
 ip address 196.1.50.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.60
 encapsulation dot1Q 60
 ip address 196.1.60.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.66
 encapsulation dot1Q 66
 ip address 196.1.66.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface FastEthernet8.77
 encapsulation dot1Q 77
 ip address 196.1.77.1 255.255.255.0
 ip nat inside
 no ip route-cache
interface GigabitEthernet0
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
interface wlan-ap0
 description Service module interface to manage the embedded AP
 no ip address
 arp timeout 0
interface Wlan-GigabitEthernet0
 description Internal switch interface connecting to the embedded AP
 no ip address
interface Vlan1
 ip address 196.1.1.2 255.255.255.0
interface Async1
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 102 interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1 254
access-list 102 permit ip 196.1.0.0 0.0.255.255 any
control-plane
mgcp profile default
line con 0
line 1
 modem InOut
 stopbits 1
 speed 115200
 flowcontrol hardware
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
 login local
 transport input ssh
end
Anyone have any ideas as to what may be causing this?
7 Replies 7
Mark Malone
that guide is based on the Verizon CM  being in bridge mode
You don't need an AD on this route remove the 254...ip route 0.0.0.0 0.0.0.0 192.168.1.1...and it should also be pointing to the public ip address of the modem or to g0 as the interface
This line ....ip nat inside source list 102 interface GigabitEthernet0 overload...its telling the router to translate your private ip range to another private ip range as your not getting a public Ip address on that interface , the reason its not working is your modem should be in bridge mode , what this does is pulls the public ip off the Verizon router and bridges it to your G0 interface where your ip nat outside is set on your cisco router , do that and your config should work fine
The command 'no ip route 0.0.0.0 0.0.0.0 192.168.1.1 254' and 'no ip route 0.0.0.0 0.0.0.0 192.168.1.1' don't seem to be working.
no ip http server
control-plane
R1(config)#no ip route 0.0.0.0 0.0.0.0 192.168.1.1 254
%No matching route to delete
R1(config)#
show ip route
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 192.168.1.1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0
L        192.168.1.4/32 is directly connected, GigabitEthernet0
      196.1.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.1.0/24 is directly connected, Vlan1
L        196.1.1.1/32 is directly connected, Vlan1
      196.1.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.10.0/24 is directly connected, FastEthernet8.10
L        196.1.10.1/32 is directly connected, FastEthernet8.10
      196.1.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.20.0/24 is directly connected, FastEthernet8.20
L        196.1.20.1/32 is directly connected, FastEthernet8.20
      196.1.30.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.30.0/24 is directly connected, FastEthernet8.30
L        196.1.30.1/32 is directly connected, FastEthernet8.30
      196.1.40.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.40.0/24 is directly connected, FastEthernet8.40
L        196.1.40.1/32 is directly connected, FastEthernet8.40
      196.1.50.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.50.0/24 is directly connected, FastEthernet8.50
L        196.1.50.1/32 is directly connected, FastEthernet8.50
      196.1.60.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.60.0/24 is directly connected, FastEthernet8.60
L        196.1.60.1/32 is directly connected, FastEthernet8.60
      196.1.66.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.66.0/24 is directly connected, FastEthernet8.66
L        196.1.66.1/32 is directly connected, FastEthernet8.66
      196.1.77.0/24 is variably subnetted, 2 subnets, 2 masks
C        196.1.77.0/24 is directly connected, FastEthernet8.77
L        196.1.77.1/32 is directly connected, FastEthernet8.77
that's strange are you copying the line straight off the router or typing it
couple ways you could sort this , take copy off your config onto notepad wipe the router with erase startup-config then reload ,then re-apply with correct default route or 2nd option add another default route along with that route that has no AD at the end and that route will take preference in the routing table as it will only have a default AD of 1
I have the same issue - I have a route in my routing table on my 2811 I cannot get rid of either:
I have cleared all static routes and it still shows up.  However, when I add the route "ip route 0.0.0.0 0.0.0.0 192.168.1.1" - The admin distance changes to 1.  See output:
R1#sh ip route
Codes: ** OMITTED CODES**
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/24 is directly connected, FastEthernet0/1
L        10.1.1.1/32 is directly connected, FastEthernet0/1
C        192.168.1.0/24 is directly connected, FastEthernet0/0
L        192.168.1.8/32 is directly connected, FastEthernet0/0
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.1 <- Adding in static default route
R1(config)#do sh ip route
Codes: ** OMITTED CODES **
S*    0.0.0.0/0 [1/0] via 192.168.1.1
R1(config)#
Hi, I've been having the same issue but I notice that the
Is set by the DHCP server and it seems it is not stored in the running config so when you try to do the 'no ip route 0.0.0.0 0.0.0.0 X.X.X.X it will therefore give the
error.
I noticed that when I booted up my router (using GNS3 connected to the outside network). Before I connected the network cable to my outside router, the default route was not appearing but as soon as I connected it and got an ip from DHCP I ran the show ip route command and the default route appeared.
Anyone with more knowledge can clarify. Does a Gateway of last resort configured automatically by DHCP not appear in running config and does DHCP somehow restrict you from deleting one of its parameters (ie the default static route that it sets)
It is a good observation that the default route with AD of 254 is generated from DHCP. If you do not have a manually configured static default route then the DHCP route (with its AD of 254) is used. If you configure your own static default route (whose default AD is 1) then it appears in the routing table and the default route from DHCP is not used.
You asked a couple of specific questions and here are the answers:
Yes the gateway of last resort learned by DHCP does not appear in the running config.
Yes DHCP does not allow you to delete one of its parameters. If you think about it the DHCP parameters are configured on the server. You are configuring your router. How would something you configure on your router change the configuration of a remote server?
Rick
Rick
Hello
your dhcp exlcued addrress ISNT negating the ip address of your subinterfaces
ip dhcp excluded-address 196.1.10.1 196.1.10.200
ip dhcp excluded-address 196.1.20.1 196.1.20.200
etc....
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0 dhcp 2
ip dhcp pool vlan x x
import all
As Mark states, your ISP is already perform NAT, So I guess there is not need for this
no ip nat outside
interface x/x
no ip nat intside
res
Paul
Kind Regards
Paul
