Next-hop and exit interface
S9539245H
A) ip route 10.0.0.0 255.0.0.0 172.16.40.1
B) ip route 10.0.0.0 255.0.0.0 serial0/0/0
AM I RIGHT?
6 Replies 6
cadet alain
No these are both incorrect, you're asked to configure a static route on routerA so the next-hop should be router B IP and the exit interface should be router A interface.
Alain
so it should be like this?
ip route 10.0.0.0 255.0.0.0 172.16.40.2
ip route 10.0.0.0 255.0.0.0 s0/1/0
Yes this is correct....
so the answer for this is 'A'
yes.
correct.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
nadakhalid122
how do i get the book of this exercise ?
TIA
