02-16-2024 09:10 AM
Hello all. I have a rather strange problem regarding the EIGRP on Nexus 93180 switches.
The simplified net topology pic is attached.
All locations are using EIGRP for routing and using the same AS number. A pair of Nexus switches(connected via VPC link) are in each DC and are part of the same L2 domain(they have the same VLANs on them, L3 VLAN interfaces with different IPs from the same subnet on them, they are connected through MPLS between DC locations).
The problem that I see is that the user network from user location 2 the for is only seen through 3850 switch in user location 1 over the direct link to user location 2. No matter what I do the network is not also seen through Nexus 93180-2 in DC 2 which has a direct link to user location 2. The Nexus 93180-2 in DC 2 has a route to the network in it's routing and topology tables but is not propagating it to the rest of the network.
The frustrating thing is that the Nexus 93180-2 in DC 2 sees the route to user network 1 in the topology table from other Nexus switches and through the 3850 switch in user location 2. 3850 switch in user location 2 also sees the user network in the topology table from user location 1 both from the Nexus 93180-2 in DC 2 and from the 3850 switch in user location 1.
I would be grateful for any help in why the Nexus 93180-2 in DC 2 is not propagating the route for user network 2 to the rest of the network.
02-16-2024 09:16 AM
This MPLS abd backdoor connect' it seem that NSK prefer path via backdoor not via mpls' Am I right?
MHM
02-16-2024 12:37 PM - edited 02-16-2024 12:37 PM
Not quite. Even though Nexus 93180-2 in DC 2 has the user network in location 2 in both routing and topology table that info is not seen on no other device. For example there is no entry in the topology table in Nexus 93180-1 in DC 2, Nexus 93180-1 in DC 1, Nexus 93180-2 in DC 1 or 3850 switch in user location 1.
02-16-2024 09:23 AM
wht is the vPC domain ID of both the sides ? do you have peer router and peet gateway configure - can you post show vpc output here.
can you post from all device show routing table (for that learning routes related to user location 1 and location 2) also eigrp neighur ship relation.
02-16-2024 01:22 PM - edited 02-16-2024 01:34 PM
These is the VPC info for the Nexus switches.
vPC domain id : 300
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : failed
Type-2 inconsistency reason : SVI type-2 configuration incompatible
vPC role : primary
Number of vPCs configured : 212
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 150s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Enabled
Virtual-peerlink mode : Disabled
vpc domain 300
role priority 90
peer-keepalive destination 192.168.169.254 source 192.168.169.253
delay restore 150
peer-gateway
layer3 peer-router
ip arp synchronize
vPC domain id : 300
vPC role : secondary
vpc domain 300
role priority 90
peer-keepalive destination 192.168.169.253 source 192.168.169.254
delay restore 150
peer-gateway
layer3 peer-router
ip arp synchronize
vPC domain id : 400
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 8
vpc domain 400
role priority 100
delay restore 150
peer-gateway
layer3 peer-router
ip arp synchronize
vPC domain id : 400
vpc domain 400
role priority 100
delay restore 150
peer-gateway
layer3 peer-router
ip arp synchronize
EIGRP neighbors - relevant ones
IP-EIGRP neighbors for process 77 VRF default
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
18 10.64.3.3 Vlan3 11 18w3d 1 50 0 18797 -> Nexus 93180-2 in DC 1
3 10.64.3.4 Vlan3 12 18w4d 1 50 0 2555 -> Nexus 93180-1 in DC 2
4 10.64.3.5 Vlan3 11 18w4d 1 50 0 2593 -> Nexus 93180-2 in DC 2
12 10.254.2.1 Vlan720 14 18w3d 1 50 0 10267 -> 3850 in user location 1
Routing table
#sh ip route 10.65.196.0
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
10.65.196.0/23, ubest/mbest: 1/0
*via 10.254.2.1, Vlan720, [90/3072], 18w3d, eigrp-Core_routing, internal
#sh ip route 10.64.16.0
10.64.16.0/23, ubest/mbest: 1/0
*via 10.254.2.1, Vlan720, [90/3328], 13:05:00, eigrp-Core_routing, internal
(sec) (ms) Cnt Num
1 10.64.3.2 Vlan3 10 18w3d 1 50 0 19461 -> Nexus 93180-1 in DC 1
0 10.64.3.4 Vlan3 13 18w3d 1 50 0 2554 -> Nexus 93180-1 in DC 2
2 10.64.3.5 Vlan3 12 18w3d 1 50 0 2592 -> Nexus 93180-2 in DC 2
14 10.254.2.1 Vlan720 10 18w3d 1 50 0 10264 -> 3850 in user location 1
Routing table
# sh ip route 10.64.16.0
*via 10.254.2.1, Vlan720, [90/3328], 13:09:12, eigrp-Core_routing, internal
(sec) (ms) Cnt Num
3 10.64.3.2 Vlan3 13 18w4d 1 50 0 19461 -> Nexus 93180-1 in DC 1
4 10.64.3.3 Vlan3 11 18w4d 1 50 0 18788 -> Nexus 93180-2 in DC 1
2 10.64.3.5 Vlan3 10 20w1d 1 50 0 2591 -> Nexus 93180-2 in DC 2
Routing table
# sh ip route 10.65.196.0
10.65.196.0/23, ubest/mbest: 2/0
*via 10.64.3.2, Vlan3, [90/3328], 18w3d, eigrp-Core_routing, internal
*via 10.64.3.3, Vlan3, [90/3328], 18w3d, eigrp-Core_routing, internal
(sec) (ms) Cnt Num
3 10.64.3.2 Vlan3 12 18w4d 1 50 0 19461 -> Nexus 93180-1 in DC 1
4 10.64.3.3 Vlan3 14 18w4d 1 50 0 18788 -> Nexus 93180-2 in DC 1
1 10.64.3.4 Vlan3 11 20w1d 1 50 0 2553 -> Nexus 93180-1 in DC 2
0 192.168.20.10 Eth1/31 14 12:01:43 2 50 0 10475 -> 3850 in user location 2
Routing table
# sh ip route 10.64.16.0 -> take note that the route is pointing to Nexus switches in DC1 as I had to increase delay on the interface towards 3850 switch on location 2 as the users where experiencing problems when traffic tried going to this network using directly attached link; quick fix to resolve user connectivity problems in user location 2
10.64.16.0/23, ubest/mbest: 2/0
*via 10.64.3.2, Vlan3, [90/3584], 07:53:38, eigrp-Core_routing, internal
*via 10.64.3.3, Vlan3, [90/3584], 07:53:38, eigrp-Core_routing, internal
EIGRP neighbors
EIGRP-IPv4 Neighbors for AS(77)
(sec) (ms) Cnt Num
3 10.254.2.3 Te2/1/4 10 18w3d 1 100 0 18791 -> Nexus 93180-2 in DC 1
2 10.254.2.2 Te2/1/4 12 18w3d 1 100 0 19459 -> Nexus 93180-1 in DC 1
0 10.254.1.2 Gi1/0/1 14 2y20w 1 100 0 10477 -> 3850 in user location 2
Routing table
Routing entry for 10.65.196.0/23
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 77
Routing Descriptor Blocks:
* directly connected, via Vlan196
Route metric is 0, traffic share count is 1
Routing entry for 10.64.16.0/23
Known via "eigrp 77", distance 90, metric 3072, precedence routine (0), type internal
Last update from 10.254.1.2 on GigabitEthernet1/0/1, 7w0d ago
* 10.254.1.2, from 10.254.1.2, 7w0d ago, via GigabitEthernet1/0/1
Route metric is 3072, traffic share count is 1
Total delay is 20 microseconds, minimum bandwidth is 1000000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
EIGRP neighbors
(sec) (ms) Cnt Num
0 192.168.20.254 Gi1/0/12 14 12:09:54 1 100 0 2594 -> Nexus 93180-2 in DC 2
2 10.254.1.1 Gi2/0/12 13 2y20w 4 100 0 10266 -> 3850 in user location 1
Routing table
Last update from 10.254.1.1 on GigabitEthernet2/0/12, 08:01:50 ago
* 10.254.1.1, from 10.254.1.1, 08:01:50 ago, via GigabitEthernet2/0/12
* directly connected, via Vlan16
02-16-2024 09:06 PM
high level i do not see any issue (since you already change the topology to use different path we can identify what is the issue
since the routes are installed from DC1 side for Location 2
check some guide lines when you using vPC :
we are not sure what kind of user experience ? they don't have connectivity or they have intermittent connection or routing loops ?
02-17-2024 12:34 PM
As for the user experience the main issue was that the network traffic from the user network in location 2 was very bad. A lot of time outs, web pages opening insanely slow if at all in some cases, when pinging resources connected to Nexuses there were timeouts, ...
Since it is now out of office hours I have now recreated the issue by removing delay on Nexus 2 in DC 2. These are the results of the routing tables on the equipment.
*via 10.254.2.1, Vlan720, [90/3072], 18w4d, eigrp-Core_routing, internal
*via 10.64.3.5, Vlan3, [90/3328], 00:01:16, eigrp-Core_routing, internal
*via 10.254.2.1, Vlan720, [90/3328], 1d11h, eigrp-Core_routing, internal
*via 10.64.3.5, Vlan3, [90/3328], 00:03:44, eigrp-Core_routing, internal
*via 10.64.3.2, Vlan3, [90/3328], 18w4d, eigrp-Core_routing, internal
*via 10.64.3.3, Vlan3, [90/3328], 18w4d, eigrp-Core_routing, internal
*via 10.64.3.5, Vlan3, [90/3328], 00:05:34, eigrp-Core_routing, internal
10.65.196.0/23, ubest/mbest: 3/0
*via 192.168.20.10, Eth1/31, [90/3328], 00:08:39, eigrp-Core_routing, internal
*via 192.168.20.10, Eth1/31, [90/3072], 00:09:05, eigrp-Core_routing, internal
Last update from 10.254.1.1 on GigabitEthernet2/0/12, 00:12:08 ago
* 10.254.1.1, from 10.254.1.1, 00:12:08 ago, via GigabitEthernet2/0/12
Everything looks as it should but the more I look at it the more it looks like a loop/glitch somewhere. I will do additional tests and try to figure this out.
If you have any additional insights please share them.
