Nexus Mac sec licensing
ashleybabajee
Hi Guys,
I would like to know if when we purchase a network advantage license do we get like an evaluation license for mac sec , if yes, then how many days does it last.
Would be grateful if someone can advise on that as i cant find anything on the cisco site
thanks
8 Replies 8
balaji.bandi
what is  model check here for support :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/licensing-options/cisco-nexus-licensing-options-guide.html
Nexus side you security license for macsec to enable  (network advantage is for cisco Catalyst as per i know).
BB
Thanks @balaji.bandi , but what i am looking for is if there's any evaluation license for mac sec and so far didnt find any information regarding that, i know we need add on security license for nexus but want to try it first.
Try below enable feature :
config)# feature macsec
BB
already tried that but it asked for a security license
WARNING: 'SECURITY_PKG' LICENSE NOT FOUND ON THE SYSTEM !!!!!!. You have tried to enable a licensed feature [MACSEC] without installing the license
I was in impression you have already security - what is the show  version - show of code feature set you have.
as i mentioned "Nexus side you security license for macsec to enable"
BB
maybe i was not clear, i dont have any security license yet but want to try mac sec and asking if theres any evaluation license , normally for mac sec we would need the security package add on license which i dont have yet.
The nxos is 9.2(3) , if we enable mac sec we will get the above error "security package not found " which is normal as we dnt have any license for mac sec
So , is there anyway to try/evaluate mac sec ?
we do not what model is this so we asked before
show version   (this give us information what code running and model of the device) - to judge what we suggesting is correct
Contact cisco partner  - they may help you to get test device.
BB
Hopefully you have not Nexus 9300-GX cause they dont support MacSec.
For others, you need Security add-on license.
ecurity
C1-N9K-SEC-M-3Y
C1-N9K-SEC-M-5Y
C1-N9K-SEC-M-7Y
C1-N9K-SEC-M-3Y
C1-N9K-SEC-M-5Y
C1-N9K-SEC-M-7Y
Cisco usually does not provide Trial or evaluation Licenses. In case you have a huge Contract, you may get one.
