Nexus N5548 port-channel load-balance - query on the show command output
russjstewart
My thanks and apologies in advance for this question as I feel I should know the answer.
I am looking at the load balancing configuration for port-channel groups on our Nexus N5548UP switches NX-OS version 7.3(5)N1(1)
The switch configuration says
"port-channel load-balance ethernet source-dest-port"
When I run the "show port-channel load-balance" command I get the following reply
Port Channel Load-Balancing Configuration:
System: source-dest-port
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-dest-mac
IP: source-dest-port source-dest-ip source-dest-mac
My confusion is over the bolded line  that says "IP: source-dest-port source-dest-ip source-dest-mac"
Why am I seeing three different load balancing options ?
I have searched the command reference guides and cannot see any explanation
Any information will be gratefully received
Thanks in advance
Actually the load balancing default settings is like below
source and destination MAC addresses, source and destination IP addresses, and source and destination TCP and UDP ports
As you configured to load balance based on UDP ports so, It took the first position then IP and then MAC.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
'source-dest-mac' is the default. Since you have 'source-dest-port' configured, that is the first option that shows up. The other two options show the precedence of the remaining algorithms.
That is how I think the output should be read...
Thank you, that seems to the the consensus. I appreciate your time
Thanks NetworkRhinos, greatly appreciated
