QoS policing when output BW changes
sead
I have a branch router with two WAN connections with different BW of 5Mbps and 2Mbps. The 2Mbps line is used as backup.
I want to put a percentage-based Policy of 80% on the interface that connects to the branch LAN, that limits a specific class of traffic.
For the moment I have the service-policy input to the LAN interface with police cir 4000000, but when my primary WAN connection is down the secondary line get congested.
Please help me with a policy map that works on both cases.
7 Replies 7
Dennis Mink
Why dont you configure it as an output policy, so cir 5000000 to the primary link and 2000000 to the secondary??
cheers
Please remember to rate useful posts, by clicking on the stars below.
Dennis the traffic that I want to limit is from a range of IPs in my LAN so I used access-list.
So I can't put the policy on the WAN interfaces.  The configuration is:
class-map match-any Sys
 match access-group 100
policy-map WAN
class Sys
police cir 4000000
 conform-action transmit
exceed-action drop
violate-action drop
access-list 100 permit ip x.x.x.x 0.0.0.255 any
Sorry, could you further explain why you think not?
BTW, if you device support embedded event scripts, you could have a script amend your policer's value with link up/down, however what Dennis was asking would probably be a much easier approach.
Joseph I have a E1-to-Ethernet converter connected to my WAN Fast-Ethernet interface.
If I put my policy outside my WAN interface, would happen that the policy will be removed during the conversion from Ethernet to E1?
I might misunderstand, by if you policy is on the router's interface, and you're making changes external to the device, other they seeing the interface bounce, it wouldn't know the bandwidth changed if you place an E1 in-line.
If, however, IPs changed, or CDP sees a change, you probably could use a EEM script to reconfigure, on-the-fly.
just create two policing queues:
for interface1:
policy-map pm-10m-out
class class-default
  shape average 10000000 ß--variable
policy-map pm-queue-mark-out
class cm-prec-4-5-out
  priority percent 33
class cm-prec-3-out
  bandwidth percent 5
 class cm-prec-2-out
  bandwidth percent 27
 class cm-prec-1-out
  bandwidth percent 5
 class class-default
  fair-queue
policy-map pm-shape-queue-out1
description *** Shape and Queue ***
class class-default
  shape average 10000000                  <-------variable
   service-policy pm-queue-mark-out
for interface2:
class class-default
  shape average 50000000 ß--variable
  priority percent 33
class cm-prec-3-out
  bandwidth percent 5
 class cm-prec-2-out
 class cm-prec-1-out
  bandwidth percent 5
 class class-default
  fair-queue
class class-default
The apply each policy to its respective WAN interface as follows:
interface 1
service-policy output pm-shape-queue1-out
interface 2
service-policy output pm-shape-queue2-out
Dennis I will try this even I have only two classes, one that needs max 80% of bandwidth and the other the rest.
@Joseph I will try EEM in a lab because I like this solution too :)
