02-11-2021 01:47 PM
Dear sir,
In my cisco 4331 router following are my configuration ad from external switch it is working fine and i can access internet as well as both the vlan each other. external switch are connected to interface GigabitEthernet0/0/0
4331 router config
ip dhcp pool vlan1
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 192.168.1.1 8.8.4.4
ip dhcp pool vlan2
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
interface GigabitEthernet0/0/0.1
bandwidth 100000000
encapsulation dot1Q 1 native
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/0.2
bandwidth 100000000
encapsulation dot1Q 2
ip address 192.168.11.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/1
bandwidth 100000000
bandwidth inherit 100000000
no ip dhcp client request tftp-server-address
ip address 192.168.1.6 255.255.255.0
ip nat outside
negotiation auto
Now i installed NIM-ES2-8-P in cisco 4331.
I can I assign ip address 192.168.11.2 in vlan 2 for NIM-ES2-8-P
So that device connected to the port of NIM-ES2-8-P should get IP from dhcp vlan 2 as well as access internet and access the device in vlan 1. for vlan 2 do i need to make that also NATIVE.
Thanks and best regards.
Mohammed Ehsan
02-11-2021 02:12 PM
the high level should work, but you need to add NAT configuration for the new IP address, which is the device doing NAT here?
or post full show run to understand better.
02-12-2021 12:34 AM
Dear sir,
Following are necessary config :-
ip name-server 8.8.8.8 8.8.4.4
ip domain name vrf Mgmt-intf mmalesayi.com
ip dhcp excluded-address 192.168.11.1 192.168.11.9
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.200 192.168.10.254
ip dhcp excluded-address 192.168.11.250 192.168.20.254
ip dhcp pool vlan1
ip dhcp pool vlan2
network 192.168.11.0 255.255.255.0
default-router 192.168.11.1
bandwidth 100000000
ip nat inside
bandwidth 100000000
ip nat inside
bandwidth 100000000
ip nat outside
negotiation auto
interface range gigabitethernet0/1/0 - 7
switchport access vlan 2
interface Vlan1
no ip address
shutdown
interface Vlan2
no ip address
shutdown
ip nat inside source list 1 interface GigabitEthernet0/0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 1 permit 192.168.0.0 0.0.255.255
My main problem is that in this scenario i am not able to get dhcp ip for client. for both the vlan.
but if the config is like :- NO interface GigabitEthernet0/0/0.2
and
interface Vlan2
no shutdown
Every thing is ok both vlan getting ip from dhcp and can ping each other but there are some device work on application APPLE AIR connected to vlan 1 that we can ping from vlan 2 client but application cannot find the device.
but client from vlan 1 can see the device through apple air application.
Also client from vlan2 can ping the device connected to switch on vlan 1 but cannot ping the switch = vlan1= ip 192.168.10.3
02-12-2021 02:48 AM
use the config below(no subinterfaces, just the Vlan (SVI) interfaces.
no ip address
bandwidth 100000000
ip nat outside
negotiation auto
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
02-12-2021 08:52 AM
02-12-2021 09:16 AM - edited 02-12-2021 09:17 AM
Since you get VLAN 1 Down, because no port associated with that.
if you associate with any of the port from this : example :
config t
switchport access vlan 1
no shutdown
Connect any device to that port, the VLAN 1 Interface will come up, kindly test and advice.
Note : i was in impression this was the real gear.
02-14-2021 11:46 PM
Dear Sir,
Sir all port of NIM-ES2-8-P is in vlan 2.
bandwidth 100000000
ip nat inside
bandwidth 100000000
ip nat inside
above interface is connected to outside switch which have vlan1 and ip = 192.168.10.2 and vlan2 ip = 192.168.11.2
My scenario from starting is like :- interface GigabitEthernet0/0/0 this connected to external switch with trunk port.
And having vlan1 and vlan2 And working fine.
Both after installing NIM-ES2-8-P. I want to use this in vlan2 and also client connected to any of the port should get ip from dhcp.
I tried to assign all the port in vlan1, still not getting IP from dhcp.
02-15-2021 12:33 AM
did you delete the subinterfaces and did you configure both the SVIs ? Post your current running configuration again...
02-15-2021 01:02 AM
Dear Sir,
I deleted both the sub-interface of interface GigabitEthernet0/0/0 and after that
no ip address
AND
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
02-15-2021 01:20 AM
odd. I tested this in a lab, and it apparently worked. Can you post your current config (sh run) again ?
02-12-2021 03:16 AM - edited 02-12-2021 03:17 AM
Thank you for the information, before i give an advise here
where is this port connecte ? - interface GigabitEthernet0/0/0
shutdown
and move the IP to below :
interface Vlan1
ip nat inside
no shutdown
interface Vlan2
ip nat inside
no shutdown
access-list 1 permit 192.168.0.0 0.0.255.255 < this should cover the NAT
Connect the device to Gi 0/1/0 and check you able to get DHCP IP from VLAN and able to get internet ?
02-12-2021 05:03 AM
On a side note, I do think there is something wrong with either the visibility and/or the timestamps of the posts. If you look at my post from 2:48AM, it contains almost the exact same information as your post from 3:16AM (minus the fact that if you shut GigabitEthernet0/0/0 down, the trunked switch connected to that interface will have no access whatsoever). So my guess is that previous posts are not visible to other users, or yours was there before mine, and I did not see it, or vice versa.
02-12-2021 05:28 AM
Not sure how the community manages (i do not have that visibility) based on post the reply i have addressed and replied.
If you look at my reply this is what i have asked ? (where is this port connecte ? - interface GigabitEthernet0/0/0)
I only suggested based on the information and assuming that user is connecting to switch port module on the router and testing ( at this stage) until user inputs where he connected G0/0/0 - we dont know?
is this make sense ?
