No aceess to both WAN links simultaneously
Jaaazman777
Hello everyone!
We suffer some problems with our remote 2811, that has two WAN links (two different ISP) - we cannot get access to both of WAN at the same time.
At first, the aim was to load balance the traffic between wan links:
  • at first we tried to use OER, but users complained about instable internet connection
  • then we tried PBR + NAT
Generelly we have just the same scheme as https://supportforums.cisco.com/docs/DOC-8313 :
  • dual WAN links
    • PPTP
    • PPPoE over ADSL
  • equal static routes
  • NAT using route map
The problem itself:
  • When both links are up,  the 1st WAN is pingable, and the 2nd is not
  • When the 1st link goes down the 2nd becomes pingable and accessible and vice versa
  • When I disabled the CEF, the 1st was still pingable and the 2nd became pingable too, but very unstable
What can cause such situation?
paolo bevilacqua
Try  updating IOS.
Juan Perez
CEF will load balance using a per-destination fashion therefore packets are forwarded towards the same path to a single destination, you can try changing it to per-packet but you should consider out of order packets.
I hope this is useful.
There is the voice trafiic travelling across the links, that's why per-packet cef balance may harm its quality.
Generally, what else can cause such kind of problem?
here is the part of the config:
interface Dialer1
description ADSL
mtu 1492
bandwidth 1000
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username <***> password <***>
crypto map vpn-out
interface Dialer2
mtu 1460
bandwidth 500
ip pim dense-mode
ip nat outside
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string 123
dialer vpdn
dialer-group 2
no peer neighbor-route
no cdp enable
ppp pfc local request
ppp pfc remote apply
ppp encrypt mppe auto
ppp authentication chap callin
ppp eap refuse
ppp chap hostname <***>
ppp chap password <***>
ppp ms-chap refuse
ppp ms-chap-v2 refuse
ppp pap refuse
crypto map vpn-out
ip route 0.0.0.0 0.0.0.0 Dialer1 track 10
ip route 0.0.0.0 0.0.0.0 Dialer2 track 20
ip route *pptp-server-ip* *pptp-server-mask* *local-pptp-gw*
*track 10 and track 20 make the dicisions according to interface line-protocol
and reachability of the gateways
