No output on Hub router when issueing a "show ip nhrp" command
KMNRuser
We are implementing a new DMVPN network on our production routers.  It is in addition to 2 existing DMVPN's that we use.
We have a hub at Headquarters, and another Hub at our DR site.
We have a tertiary DR site where we are trying to implement.
When i issue a "sho ip nhrp" on our HQ router, we get the following output:
HQrouter#sho ip nhrp
10.101.2.3/32 via 10.101.2.3
Tunnel1 created 11w4d, expire 00:05:12
Type: dynamic, Flags: registered nhop
NBMA address: 10.140.0.27
10.101.2.8/32 via 10.101.2.8
Tunnel1 created 10w2d, expire 00:05:04
NBMA address: 10.140.0.20
10.101.2.27/32 via 10.101.2.27
Tunnel1 created 03:34:32, expire 00:04:58
Type: dynamic, Flags: unique registered nhop
NBMA address: 10.100.0.27
10.101.2.40/32 via 10.101.2.40
Tunnel1 created 1w2d, expire 00:04:40
NBMA address: 10.100.0.1
When i issue the same command on the DR router, it comes up thusly:
TertiaryDRrouter#sho ip nhrp
TertiaryDRrouter#
The configuration on the DR router is as follows:
interface Tunnel5
ip address 10.101.5.1 255.255.255.0
no ip redirects
ip mtu 1400
ip hold-time eigrp 13 30
no ip next-hop-self eigrp 13
no ip split-horizon eigrp 13
ip nhrp authentication cisco
ip nhrp network-id 100000
ip nhrp holdtime 360
ip tcp adjust-mss 1360
delay 1000
tunnel source Loopback100
tunnel mode gre multipoint
tunnel key 100000
My team and i are trying to figure out what is missing and why we do not have that same output on the DR router..
Any help would be greatly appreciated!
KMNRuser
This is bug
Remove
Ip nhrp shortcut <<- from spoke tunnel
Shut/no shut tunnel
And check again
MHM
MHM Cisco World,
Thanks for the response.
from the spoke router, i did remove the "ip nhrp shortcut" command, and then also issued the shut/no shut.
I then on the Hub router issued the "sho ip nhrp" command again, but without success > there is nothing returned.
What makes this more interesting is that when I perform a "sho ip int bri" command, it shows my tunnel as up..
When i issue the "sho ip nhrp" command on the spoke, it gives me the following:
SPOKERTR#sho ip nhrp
10.101.2.1/32 via 10.101.2.1
Tunnel1 created 10w3d, never expire
Type: static, Flags:
NBMA address: 10.101.1.1
10.101.3.1/32 via 10.101.3.1
Tunnel2 created 10w3d, never expire
NBMA address: 10.101.1.254
10.101.4.1/32 via 10.101.4.1
Tunnel3 created 10w3d, never expire
NBMA address: 10.101.1.253
10.101.1.254/32 via 10.101.1.254
Tunnel5 created 00:06:30, never expire
NBMA address: 10.101.5.1
SPOKERTR#
