no Routing Dynamic command in ios xe
asim.mz99
hi
I am trying to find "no dynamic routing" command for IOS xe, this command is not running on iosxe so do we have an alternate command?
what is the routing protocol you are planning to disable? check this
https://learningnetwork.cisco.com/s/question/0D53i00000KsxupCAB/no-routing-dynamc-command
Good luck
KB
This command is use for blocking routing updates from tunnel interface and it is configured on tunnel. Now we are migrating to IOSXE but I cannot find this command or its alternate.
routing update, why you not use passive interface ??
asim.mz99
I don't know but why these each command co-exists, there must be a difference
