NTP configuration guide - 12.4T
layer3
Hi all,
Does anyone know where I can find the NTP configuration guide for IOS 12.4T ?
I think it used to be here..
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_basic_sys_manage_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Thanks in advance.
Mario.
6 Replies 6
Latchum Naidu
See the below link may help you...
http://www.cisco.com/en/US/docs/switches/lan/catalyst5000/catos/5.x/configuration/guide/ntp.html
Please rate the helpfull posts.
Naidu.
Thanks for the reply Naidu.
But I'm specifically after the location of the 12.4T IOS NTP configuration guide.
I hope the below link shall help you...
http://www.ccievoiceguide.com/2010/07/cisco-ios-ntp-configuration.html
Naidu.
I believe there hasn't been any change in NTP configuration since 12.1 which you can find it here.
http://www.cisco.com/en/US/docs/ios/12_1/configfun/configuration/guide/fcd303.html#wp1001170
Rama
masyamad
Could you download complete book pdf from here?
http://www.cisco.com/en/US/partner/docs/ios/netmgmt/configuration/guide/12_4t/nm_12_4t_book.html
Page38 shows NTP configuration.
Masahiro.
benizepam
Masahiro got it right:
It was moved from Cisco IOS Fundamentals Configuration Guide to Network Management Configuration Guide.
Cisco IOS Network Management Configuration Guide, Release 12.4T > Basic System Management > Performing Basic System Management > Setting Time and Calendar Services
The strange thing is, you need to download the PDF because apparently it disappeared from the online version. It still in the Network Management Command reference though.
