number of DMVPN spokes
Adis Cato
How many spoke devices can connect to the Cisco 2951 router as DMVPN hub? On which parameters in the router data sheet specification I should to pay attention so figured this out?
6 Replies 6
Lei Tian
There are some hard limited number like number of ipsec tunnel, encryption throughput for ISR G2, You can find it from
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/ps12202/data_sheet_c78-682436.html
In term of the max number of spokes 2950 can support for DMVPN design, you also need to consider the routing protocol, features that will be enabled, authentication/encryption mode. We have some internal scalability testing document of ISR G2 for DMVPN, please reach out your cisco SE for that information.
HTH,
Lei Tian
paolo bevilacqua
Let's put it another way, how many do you need? For example 20 or 200 is no big deal, while 2000 may need some care in design.
to be precise, I need a router that can be a hub for 325 dmvpn spoke routers. Any advice?
People from the local Cisco office recommended me ASR1000, but it is a very expensive device.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The number of spokes will have an impact on router load, but how much traffic will be passing across DMVPN  tunnels perhaps even more so.
Cisco recommends a 2951 for up to 500 IPSec tunnels, and 103 Mbps, see Table 7 in attachment.
Can any one confirm how many IP sec tunnel support by Cisco 892 router ?
Hi Zubair,
890 routers support the maximum of 50 IPSec tunnels with Security license. Maximum IPSec throughput can be 125 Mbps but the maximum speed of WAN circuit supported is 15 Mbps.
Spooster IT Services Team
