NX7K ACL Configuration
zekebashi
Level 4
Level 4
We have a NX7K with two connections(e5/9 and e6/9) to our ISP. We use eBGP peering the two interfaces with the ISP. We tried to implement an iACL to deny ssh and snmp ingress traffic from out ISP to the NX7K but after implementing the iACL we experienced an Internet outage. It seems that the implementation of this iACLs broke the BGP peering for some reason. Here's the iACL we implemented:
IP access list DENY_ACCESS
        statistics per-entry
        10 deny tcp any any eq 22 log
        15 deny udp any any eq snmp log
        20 permit tcp any any
interface Ethernet5/9
ip access-group DENY_ACCESS in
exit
interface Ethernet6/9
exit
Can anyone see why this iACL  would cause the bgp peering to break?
Thanks in advance.
~zK
Hi zekebashi,
Is there any specific reason to add  "20 permit tcp any any" in the last of the ACL instead of permit ip any any ?
It may be happened that BGP peering was good at that time but other traffic like udp (DNS etc) was dropped by this ACL due to which you were facing an issue to access internet.
Spooster IT Services Team
Collin Clark
I would specifically allow BGP first, then block, then permit.
object-group network BGP_LOCAL_IP
 host 198.51.100.130
object-group network BGP_NEIGHBOR_IP
 host 198.51.100.129
ip access-list extended iACL
 remark Allow BGP
 permit tcp object-group BGP_NEIGHBOR_IP eq bgp object-group BGP_LOCAL_IP
 permit tcp object-group BGP_NEIGHBOR_IP object-group BGP_LOCAL_IP eq bgp
deny tcp any object-group BGP_LOCAL_IP eq 22 log
deny udp any object-group BGP_LOCAL_IP eq 161 log
permit ip any any
