Vlan blocking
pcromwell
Level 3
Level 3
I have 5 vlans on a l3 switch e.g vlan 1-5. running hosts as a multi tenenancy. I want to let vlan 1 access all the hosts on all the vlan but I do not want vlans 2,3 4,and 5  to be able to acces any hosts excpept on their own vlan. I have looked at ACLs and Private vlans but am not sure how to go about it. VRFs seem to be more than what I need. can anyone suggest a simple config?
5 Replies 5
Manish Gogna
Here are a couple of posts with similar queries that you can refer
https://supportforums.cisco.com/discussion/11586626/block-traffic-under-two-vlans-unidirectional-or-bidirectional
https://supportforums.cisco.com/discussion/11778006/preventing-inter-vlan-routing
Manish
you could use VACLs. Let's say you have five Vlans:
Vlan 10/192.168.10.0/24
Vlan 20/192.168.20.0/24
Vlan 30/192.168.30.0/24
Vlan 40/192.168.40.0/24
Vlan 50/192.168.50.0/24
The below config would allow all Vlans to access Vlan 10, but allow all the other Vlans only to be access by hosts from within that Vlan. I hope I didn't make any typos, but you get the idea:
ip access-list extended VLAN10_TO_ALL
 permit ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
 permit ip 192.168.30.0 0.0.0.255 192.168.10.0 0.0.0.255
 permit ip 192.168.40.0 0.0.0.255 192.168.10.0 0.0.0.255
 permit ip 192.168.50.0 0.0.0.255 192.168.10.0 0.0.0.255
vlan access-map VLAN10_MAP
 match ip address VLAN10_TO_ALL
  action forward
vlan filter VLAN1_MAP vlan-list 10
ip access-list extended VLAN20_TO_SELF
 permit ip 192.168.20.0 0.0.0.255 192.168.20.0 0.0.0.255
vlan access-map VLAN20_MAP
 match ip address VLAN20_TO_SELF
  action forward
vlan filter VLAN20_MAP vlan-list 20
ip access-list extended VLAN30_TO_SELF
 permit ip 192.168.30.0 0.0.0.255 192.168.30.0 0.0.0.255
vlan access-map VLAN30_MAP
 match ip address VLAN30_TO_SELF
  action forward
vlan filter VLAN30_MAP vlan-list 30
ip access-list extended VLAN40_TO_SELF
 permit ip 192.168.40.0 0.0.0.255 192.168.40.0 0.0.0.255
vlan access-map VLAN40_MAP
 match ip address VLAN40_TO_SELF
  action forward
vlan filter VLAN40_MAP vlan-list 40
ip access-list extended VLAN50_TO_SELF
 permit ip 192.168.50.0 0.0.0.255 192.168.50.0 0.0.0.255
vlan access-map VLAN50_MAP
 match ip address VLAN50_TO_SELF
  action forward
vlan filter VLAN50_MAP vlan-list 50
Hello Georg
VLAN10_TO_ALL -> Wouldnt this allow communication to and from other vlans, not just orignating from vlan 10
res
Paul
Kind Regards
Paul
I forgot one line in that access list, without which hosts in Vlan 10 wouldn't be able to talk to each other:
 permit ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
Either way, the idea is that the implicit deny at the end of the VACL would not allow anything other than what is specified...
Hello
Edited- apologies misread OP - as it states no communcation for the other vlans also!
Example below will allow vlan 1 to establish commincation to the other vlans but not for traffic from the other vlans initiated towards vlan 1
Vlan 2 wont allow any communiation between vlan 3,4,5 and just established tcp and icmp replys for vlan 1
ip access-list extended vlan1
permit tcp 2.2.2.0 0.0.0.255 any established
permit tcp 3.3.3.0 0.0.0.255 any established
permit tcp 4.4.4.0 0.0.0.255 any established
permit tcp 5.5.5.0 0.0.0.255 any established
deny ip 2.2.2.0 0.0.0.255 any
deny ip 3.3.3.0 0.0.0.255 any
deny ip 4.4.4.0 0.0.0.255 any
deny ip 5.5.5.0 0.0.0.255 any
permit ip any any
int vlan 1
Ip access-group vlan1 out
ip access-list extended vlan2
deny   icmp 3.3.3.0 0.0.0.255 any
deny   icmp 4.4.4.0 0.0.0.255 any
deny   icmp 5.5.5.0 0.0.0.255 any
permit ip any any
int vlan2
Ip access-group vlan2 out
etc........
res
Paul
Kind Regards
Paul
