Odd inter vlan routing
CapUcisco
2 switches
switch 1 (3550) does the routing with OSPF
vlan 74 with ACL on
vlan 100
vlan 200
switch 2 (3750) is a layer 2 switch with SVIs
vlan 74 with ACL on
vlan 100
vlan 200
There is a Layer 2 trunk between the two switches with native Vlan 100
The problem is:
When a packed coming from vlan 100 in switch 1 with a destination of vlan 200 on switch 2 the route of the packet goes via vlan 74 on switch 2 first and it hits the ALC and therefor it gets dropped.
Why is that packet traversing vlan 74 first.
It should go vlan 100 (sw1) to vlan 200 (sw2) directly
Am I wrong?
12 Replies 12
manish arora
Level 6
Level 6
Yes it should go from vlan 100 to vlan 200 given everything is configured correctly :-). Would you please post "show ip route" from both sw1 & sw2 ?
Manish
The actual vlan # are:
Vlan74                 10.7.4.10       YES NVRAM  up                    up
Vlan562                10.56.16.10     YES NVRAM  up                    up
Vlan572                10.57.16.10     YES NVRAM  up                    up
Vlan582                10.58.16.10     YES NVRAM  up                    up
Vlan592                10.59.16.10     YES NVRAM  up                    up
Vlan602                10.60.16.10     YES NVRAM  up                    up
Vlan612                10.61.16.10     YES NVRAM  up                    up
Vlan622                10.62.16.10     YES NVRAM  up                    up
Vlan 74 is the only one with an ACL on it.
switch 1
show ip route
Gateway of last resort is 172.19.56.45 to network 0.0.0.0
     172.19.0.0/16 is variably subnetted, 24 subnets, 2 masks
O       172.19.253.64/32 [110/3] via 172.19.56.45, 1d17h, GigabitEthernet0/2
                         [110/3] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.252.80/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.252.84/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.252.88/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.252.92/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.253.59/32 [110/3] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.253.56/32 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.253.57/32 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.253.62/32 [110/3] via 172.19.56.45, 1d17h, GigabitEthernet0/2
C       172.19.253.63/32 is directly connected, Loopback0
O       172.19.253.60/32 [110/3] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.253.61/32 [110/3] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.56.4/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.56.0/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.56.12/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.56.8/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.56.20/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.56.16/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.56.28/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.56.24/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       172.19.56.36/30 [110/2] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       172.19.56.32/30 [110/2] via 172.19.56.41, 1d17h, GigabitEthernet0/1
C       172.19.56.44/30 is directly connected, GigabitEthernet0/2
C       172.19.56.40/30 is directly connected, GigabitEthernet0/1
     10.0.0.0/8 is variably subnetted, 27 subnets, 2 masks
C       10.7.4.0/23 is directly connected, Vlan74
O       10.58.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
                      [110/9] via 172.19.56.41, 1d17h, GigabitEthernet0/1
O       10.59.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.56.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.57.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.62.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.60.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.61.40.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
C       10.58.16.0/21 is directly connected, Vlan582
C       10.59.16.0/21 is directly connected, Vlan592
C       10.56.16.0/21 is directly connected, Vlan562
C       10.57.16.0/21 is directly connected, Vlan572
C       10.62.16.0/21 is directly connected, Vlan622
C       10.60.16.0/21 is directly connected, Vlan602
C       10.61.16.0/21 is directly connected, Vlan612
O       10.58.24.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.59.24.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.56.24.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.60.24.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.58.0.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.59.0.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.56.0.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.57.0.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.58.8.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.59.8.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.56.8.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
O       10.57.8.0/21 [110/9] via 172.19.56.45, 1d17h, GigabitEthernet0/2
S*   0.0.0.0/0 [1/0] via 172.19.56.45
               [1/0] via 172.19.56.41
switch 1
show ip inter br
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/1     172.19.56.42    YES NVRAM  up                    up
GigabitEthernet0/2     172.19.56.46    YES NVRAM  up                    up
Loopback0              172.19.253.63   YES NVRAM  up                    up
switch2
show ip route
Default gateway is not set
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
This switch is Layer 2 trunked to sw 1
switch 2
show ip inter br
Vlan74                 10.7.4.11       YES NVRAM  up                    up
Vlan562                10.56.16.11     YES NVRAM  up                    up
Vlan572                10.57.16.11     YES NVRAM  up                    up
Vlan582                10.58.16.11     YES NVRAM  up                    up
Vlan592                10.59.16.11     YES NVRAM  up                    up
Vlan602                10.60.16.11     YES NVRAM  up                    up
Vlan612                10.61.16.11     YES NVRAM  up                    up
Vlan622                10.62.16.11     YES NVRAM  up                    up
Layer 2 Etherchannel between the 2 switches:
interface Port-channel45
 description Ma112sw1 Trunk
 switchport trunk native vlan 562
 switchport mode trunk
Just labbed it up  and I am unable to replicate your problem. Can you shed more light in to your issue with reference to correct vlans as in your config ? Also, any traceroutes showing that your switch is taking an extra hop before going to a different vlan would be good along with ACL logs when packets hit the access-group on vlan 74 would be helpful in finding the issue.
Also, can you double check that same vlans are present in both switches in the "Show vlan brife" or if using vtp , the switches are in sync ?
Manish
Both switches have these vlans, (VTP is in transparent mode)
Vlan74, 562, 572, 582, 592, 602, 612, 622
Vlan74 is the only one that has an ACL attached to its SVI
The native Vlan on both sides of the trunk is Vlan 562
This is a trace from sw1 Vlan 582 SVI to sw2 Vlan 592 SVI
Ma112sw1#trace
Protocol [ip]:
Target IP address: 10.59.16.11
Source address: 10.59.16.10
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Tracing the route to ma112sw2-vlan592.capilanou.ca (10.59.16.11)
  1 ma112sw2-vlan592.capilanou.ca (10.59.16.11) 0 msec *  12 msec
Ma112sw1#
This is as expected.
Now watch what happens with this trace mac from switch 1 between the last 2 hosts in the arp table, hosts attached to the same switch 1 in vlan 592
Ma112sw1#sh arp | i 592
Internet  10.59.16.1              -   0000.0c07.acc0  ARPA   Vlan592
Internet  10.59.16.3              0   442b.0391.479f  ARPA   Vlan592
Internet  10.59.16.2              0   442b.03d8.b602  ARPA   Vlan592
Internet  10.59.16.11           110   44d3.ca6f.b645  ARPA   Vlan592
Internet  10.59.16.10             -   000c.316a.aa80  ARPA   Vlan592
Internet  10.59.20.21           101   000a.9c10.75f3  ARPA   Vlan592
Internet  10.59.20.22             0   0002.3102.224d  ARPA   Vlan592
Internet  10.59.20.25             6   00e0.d812.6d0a  ARPA   Vlan592
Internet  10.59.20.24             9   0020.85fb.690b  ARPA   Vlan592
Internet  10.59.20.101            0   0018.badc.c514  ARPA   Vlan592
Internet  10.59.20.100            0   0017.e095.0ef8  ARPA   Vlan592
Internet  10.59.20.110            4   0019.ee00.029b  ARPA   Vlan592
Ma112sw1#sh mac add
Ma112sw1#sh mac address-table | i 0ef8
 592    0017.e095.0ef8    DYNAMIC     Fa0/44
Ma112sw1#sh mac address-table | i 029b
 592    0019.ee00.029b    DYNAMIC     Fa0/43
Ma112sw1#trace mac 0017.e095.0ef8 0019.ee00.029b
Source 0017.e095.0ef8 found on Ma112sw1
1 Ma112sw1 (10.7.4.10) : Fa0/44 => Fa0/43
Destination 0019.ee00.029b found on Ma112sw1
Layer2 trace completed.
This line 1 Ma112sw1 (10.7.4.10) : Fa0/44 => Fa0/43
indicates that traffic is flowing via 10.7.4.10 which is the SVI of vlan 74 on sw1 (this is the vlan that has the ACL)
Now the ACL log:
this is the config of SVI on vlan 74
Ma112sw1#sh run interface vlan 74
Building configuration...
Current configuration : 363 bytes
interface Vlan74
 description 10.7.4-CSU-Maple
 ip address 10.7.4.10 255.255.254.0
 ip access-group Filter-CSU-Network in
 ip helper-address 204.239.154.50
 ip helper-address 204.239.154.189
 no ip redirects
 ip directed-broadcast
 ip pim sparse-mode
 ip ospf cost 7
 standby name vlan74
 standby 74 ip 10.7.4.1
 standby 74 priority 95
 standby 74 preempt
end
and this is the SVI of vlan 592
Ma112sw1#sh run interface vlan 592
Current configuration : 340 bytes
interface Vlan592
 description 10.59.16-Maple-1xx-Mgmt
 ip address 10.59.16.10 255.255.248.0
 no ip redirects
 ip pim sparse-mode
 ip ospf cost 7
 standby name vlan592
 standby 192 ip 10.59.16.1
 standby 192 priority 95
 standby 192 preempt
end
%SEC-6-IPACCESSLOGP: list Filter-CSU-Network denied tcp 10.59.16.11(23) -> 204.239.152.212(60198), 1 packet
From my computer 204.239.152.212 I'm trying to initiate a telnet session to ma112sw1 with ip 10.59.16.11 this is on vlan 592 without any ACL as you can see above
But still the ACL applied to vlan 74 is dropping the packet
Even more interesting.
A layer 2 trace between two hosts attached to vlan 592 on sw1 reveals:
Internet  10.59.16.11             8   44d3.ca6f.b645  ARPA   Vlan592
Internet  10.59.20.21           116   000a.9c10.75f3  ARPA   Vlan592
Internet  10.59.20.22            15   0002.3102.224d  ARPA   Vlan592
Internet  10.59.20.25            11   00e0.d812.6d0a  ARPA   Vlan592
Internet  10.59.20.24             4   0020.85fb.690b  ARPA   Vlan592
Internet  10.59.20.110            8   0019.ee00.029b  ARPA   Vlan592
Ma112sw1#
Ma112sw1#
Ma112sw1#
address 10.7.4.10 is the SVI of vlan 74 on sw1 (this is the vlan with the ACL on)
I also get this logs on sw1
 %FM-3-UNLOADING: Unloading input vlan label 2 feature from all TCAMs
41w5d: %FM-3-UNLOADING: Unloading input vlan label 4 feature from all TCAMs
Logs on SW1 suggests ACL is consuming more memory than allotted by the Cisco.
I can see your issue now and its really baffling, can you please test this out and post results :
#traceroute mac ip 10.59.20.100 10.59.20.110
Also, Can you please run the similar traceroute mac's ( with both source & dest on SW2 only) on the SW2 ( 3750) which is much newer than 3550  and see if the results are same or different ?
Ma112sw1#sh ip inter br | e unass
Ma112sw1#
Ma112sw1#
Internet  10.59.16.11           120   44d3.ca6f.b645  ARPA   Vlan592
Internet  10.59.20.21           111   000a.9c10.75f3  ARPA   Vlan592
Internet  10.59.20.22            10   0002.3102.224d  ARPA   Vlan592
Internet  10.59.20.25            14   00e0.d812.6d0a  ARPA   Vlan592
Internet  10.59.20.24             6   0020.85fb.690b  ARPA   Vlan592
Internet  10.59.20.110            0   0019.ee00.029b  ARPA   Vlan592
Ma112sw1#
Ma112sw1#
Ma112sw1#trace
Ma112sw1#traceroute
Protocol [ip]:
Target IP address: 10.59.20.110
Source address: 10.59.20.100
% Invalid source address
Ma112sw1#traceroute
Protocol [ip]:
Probe count [3]:
Tracing the route to ma000-mtr1.capilanou.ca (10.59.20.110)
  1 ma000-mtr1.capilanou.ca (10.59.20.110) 0 msec 4 msec 0 msec
Ma112sw1#
Trace mac on sw2
Ma112sw2#sh arp | i 562
Internet  10.56.20.35             1   90e6.bac2.7950  ARPA   Vlan562
Internet  10.56.20.44             0   d4be.d9a4.f503  ARPA   Vlan562
Internet  10.56.20.43             2   d4be.d9a5.c2a4  ARPA   Vlan562
Internet  10.56.20.41             2   90b1.1ca2.bde0  ARPA   Vlan562
Internet  10.56.16.1            120   0000.0c07.aca2  ARPA   Vlan562
Internet  10.56.16.10            27   000c.316a.aa80  ARPA   Vlan562
Internet  10.56.16.11             -   44d3.ca6f.b642  ARPA   Vlan562
Ma112sw2#
Ma112sw2#
Ma112sw2#
Ma112sw2#
Ma112sw2#trace mac
Ma112sw2#sh mac add | i f503
 562    d4be.d9a4.f503    DYNAMIC     Gi1/0/23
Ma112sw2#sh mac add | i c2a4
 562    d4be.d9a5.c2a4    DYNAMIC     Gi1/0/21
Ma112sw2#trace mac d4be.d9a4.f503 d4be.d9a5.c2a4
Unable to send a l2trace request to 10.58.23.246. Timed out
Layer2 trace aborted.
Ma112sw2#
Ma112sw2#sh arp | ii 23.246
% Invalid input detected at '^' marker.
Ma112sw2#sh arp | i 23.246
Internet  10.58.23.246            4   c8f9.f968.aed0  ARPA   Vlan582
Ma112sw2#sh mac add | i aed0
 562    c8f9.f968.aed0    DYNAMIC     Gi1/0/23
 582    c8f9.f968.aed0    DYNAMIC     Gi1/0/23
Ma112sw2#
Odd, 10.58.23.246 is a Cisco phone
Ok, The "Traceroute mac xxx xxx" command shows the smallest vlan IP add as a switch id in the output, in your case it's showing VLAN74, if you create another VLAN for example VLAN55 with smaller IP Subnet than vlan 74 , it will start showing that in the output of your "traceroute mac" command , as far as ACL log being hit when you try to telnet from PC than please run a traceroute from your PC and see if vlan74 shows up as one of the next hop in that path or not.
Manish
actually a trace from my pc to a pc in vlan 562 on sw2 does not show touching vlan 74
But a trace from sw2 back to my pc shows the route hits the 10.7.4.10 with is the SVI on sw1 with the ACL applied
10.59.16.11 is the SVI of vlan 592 on sw2
Ma112sw2#traceroute
Protocol [ip]:
Target IP address: 204.239.152.212
Source address: 10.59.16.11
Probe count [3]:
Tracing the route to vhutanu1.cds.capilanou.ca (204.239.152.212)
  1  *
    10.7.4.10 !A  *
As u mention above:
but your configuration show: your native vlan 562, may be native vlan mismatch on both sides or one switch have command switchport access vlan 74
"please rate if post helpful"
Sorry, I started my first post with different Vlan numbers.
The actual vlan numbers are in the config example below
Both trunks have native vlan 562
