Only allow multicast traffic between two specific interfaces
Tom22
Is it somehow possible to route the traffic of specific multicast stream between two interfaces and block it on all others, instead of letting the switch discovering the path itself?
Basically we would like to enforce that the traffic can only go via a specific egress interface, so that we can manage the bitrate capacity ourselves.
I think we don't need PIM, NMB etc. (not sure). Just a simple routing for a multicast group and source IP, between ingress and egress interface.
A lot of information can be found on the internet regarding multicast routing on Cisco, but it's hard to figure out the configuration that we need.
This is how we've imlemented it sucessfully on Arista switches
- disable PIM on the interfaces
- create a route between two interfaces using the following commands
- router multicast;ipv4;routing;route {multicastIP} {sourceIP} iif {sourceItf} oif {destinationItf}
Switch model:
Cisco Nexus N9K-C93180YC-FX
8 Replies 8
balaji.bandi
how about ACL ? what device is this ?
BB
Tom22
chrihussey
I've never had to implement it, but look into defining a static multicast route (ip mroute command).
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/multicast/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Multicast_Routing_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Multicast_Routing_Configuration_Guide_chapt...
Looks like you base it on the multicast source and point it to the interface you want it to take. Seems to be no control in specifying which multicast groups it applies to though.
Hope this helps
Harold Ritter
Hi @Tom22 ,
You should be able to do more or less what you do on the Arista box by configuring the following.
"ip pim sparse-mode" on the ingress and egress interface
and
"ip igmp static-oif <multicast group address> source <source ip address>" on the egress interface.
If you only apply the "ip pim sparse-mode" on the interfaces you want to be used, then multicast won't be active on any other interfaces.
Tom22
All interfaces will be used for multicast, so we cannot disable it for the whole interface. But we want full control over which multicast goes to which egress interface to be able to manage the capacity of that link.
Will the multicast not automatically switch to another interface when the link goes down for whatever reason? Another big downside of this approach is that other multicasts are not blocked by default and thus potentially interfering with our streams. How can we make sure that only the traffic we want goes through the interface?
Hello
You can negate an interface to join or be denied to join a specific group thus allowig MC through the pim interface but you are controlling what is allowed.
ip access-list standard noMC
deny 224.x.x.x.
permit any
int x/x
ip igmp access-group noMC
Kind Regards
Paul
Tom22
The following page seems to describe exactly what we want to achieve: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/ip-fabric-for-media/solution/guide/b-cisco-nexus-9000-nx-os-ip-fabric-for-media-solution-guide-93x/b-cisco-nexus-9000-nx-os-ip-fabric-for-media-solution-guide-93x_chapter_011..... Especially the 'Configuring an NBM VRF for Static Flow Provisioning' section.
"You can configure an NBM VRF for static flow provisioning, which allows the NBM fabric to form a multicast flow with assistance from an external controller."
But for some reason we are not able to execute the steps on that page.
First we change the NBM mode to passive:
- configure terminal
- nbm vrf nbm
- nbm mode pim-passive
Then we continue with establishing a flow:
- nbm flow-definition 235.1.1.13 100.1.1.40
After the last command we get the following error: "flow-definition cannot be configured when NBM is in PIM-PASSIVE mode".
Is there something else that needs to be enabled/disabled first? Other required steps?
