Option 43 configuration L3 Swit
Terence Payet
Hi expert,
I want to configure option 43 on a cisco 4500, and wanted to know on how to go about it.
Basically I want to include a URL of a management server + username and password.
note that the dhcp server is on the 4500.
thanks in advance.
regards,
Steve
Markus Benz
Hi Terence,
did you try with a config like this (example)?
ip dhcp pool TEST
 network 10.0.0.0 255.255.255.0
 default-router 10.0.0.1
 dns-server 10.1.1.10
 domain-name your-domain.com
and then just add option 43 in either hex or ascii:
 option 43 ascii “Comma Separated IP Address List”
 option 43 hex "hex string"
I hope that helps.
Markus
