OSPF adjacency steps
kamlesh.sharma
Level 3
Level 3
Hi friends,
According to attached documentation.
I was thinking that in exstart state DDP coming from Chardonnay should have M bit value 0 because shiraz has highest ip and Chardonnay has lower. SO shiraz will become Master for this DDP exchange.
Please help.
Kamlesh Sharma
amit-singh
Level 8
Level 8
Yes, Kamlesh. You are right..
Shiraz will be the master as it has highest IP address.
There are 4 steps in adjacency formation :
1. Neighbor relationship
2. Bi-directional relationship i.e 2way
3. Exchange of DD packets
4. Full adjacnecy ( Full state)
In this case after the 2-way state Shiraz will become the master as it has the highest IP and when it will send the first DD packet it will set the Initial Bit (I=1) Morebit ( M=1) and Masterslave bit(MS=1) and will get the reply from Chardonnay with MS bit set to 0 as it is the slave.
HTH,
-amit singh
