OSPF Advertisement
newnetman
Hello All,
Can someone please help clarify the difference between:
network 0.0.0.0 0.0.0.0 area xx
network 0.0.0.0 255.255.255.255 area xx
When advertising networks in OSPF?
Many thanks in Advance
8 Replies 8
Marwan ALshawi
in the network field 0 mean any
in the wildcard field 255 means any
if helpful Rate
Sir,
If in the wildcard field 255 means any, What would the following mean then?,
because i am still confused if 0.0.0.0 in the wildcard field means "specificity", what would it then care about in the network field with 0.0.0.0?.
the mask in wild card 0.0.0.0 mean host
if u wanna advertise host u give it this wildcard
this is actually confusing. i cant find any documentation so the best way to verify this is on a lab or actual scenario. if you encountered this on the actual network, then you definitely have a clue by using show ospf commands and see what is being advertise by the router.
I'm not sure about this, but I think if you type the following....
router ospf
....it will show in the "show run" as;
router ospf
Edison Ortiz
The IOS will change the command
to
As the first command isn't valid. The subnet portion will determine what to match from the network portion. If the network portion is all 0s, there is nothing to match so the correct subnet mask is 255 (don't care bits).
HTH,
__
Edison.
Thanks Ed, that confirms my theory :)
HAi Edi,
That was really helpfull one ...
thanks ...
Lijesh.N.C
