12-20-2009 05:58 AM - edited 03-04-2019 07:01 AM
When OSPF is enabled on serial point-to-point link how hellos are sent to other end router? Are hello packets are sent as multicasts?
If yes what is the IP address as destination and source ( source - most likely IP address of serial interface )
To form a neighbor relationship intial hellos are to be received from neighbor and periodic hellos are requred to sustain the already formed
adjacency. What are the IP address of the hellos after adjacency is established or is it the same? Is it so that once adjacency is established hellos are sent as unicast to other end of router?
In short
Case 1. OSPF Hello packet - source IP and Destination IP while adjacency is getting established ?
Case 2. OSPF Hello packet - soiurce IP and Destination IP after adjacency is established?
On similar lines how hellos are sent in EIGRP case?
Please share the experience.
Subodh
Solved! Go to Solution.
12-20-2009 06:13 AM
Hellos are always multicast unless you configure an explicit neighbor.
All this is explained in the documentation that I recommend you to read.
12-20-2009 06:13 AM
12-20-2009 12:23 PM
hello,
Ospf destination address for all routers: 224.0.0.5
ospf destination address for DR/BDR: 224.0.0.5
Eigrp multicast address : 224.0.0.10
thanks
vinod
12-20-2009 12:38 PM
small typo, ospf dr is 224.0.0.6
12-21-2009 02:07 AM
Dear Subodh,
You can also see the multicast packets by the following debug commands:
#debug ip packet detail
#debug ip ospf hello
Anser
12-21-2009 02:09 AM
Dear Subodh,
Anser
