OSPF- Distribute-list
vinodbharwani
Can any one tell me , why i am getting this msg on router only in OSPF
R1(config-router)#distribute-list 1 out serial 2/3
% Interface not allowed with OUT for OSPF
Edison Ortiz
"You cannot specify an interface name in OSPF. When used for OSPF, this feature applies only to external routes."
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hirp_c/ch20/piconfig.htm#wp1001343
Vinod
Edison makes a good point about specifying an interface name in OSPF distribute list. I would like to go a bit deeper about the use of distribute list in OSPF. Unlike routing protocols like EIGRP or RIP which do advertise routes, OSPF advertises LSAs. Since a distribute list filters advertisement of routes it is not effective in filtering of LSAs and can not assigned outbound on an interface.
Rick
Rick
also....
The command distribute-list out works only on the routes being redistributed by the Autonomous System Boundary
Routers (ASBRs) into OSPF. It can be applied to external type 2 and external type 1 routes, but not to intra-area
and interarea routes.
arun ..:)
