OSPF inter Router Link
Charlie Grey
refer to diagram.
Do we need 2 x L3 links btw the 2 LAN router? ie. 1 for area 0 and 1 for area 2??
or recommended just 1 L3 for Area 2??
i am confused.
Hello
those L1-2 rtr will only require an interconnection in area 2 for resilience regards area 2 and it's wan connectivity.
You shouldn't  require an additional interconnection as you have shown in your diagram for area 0 unless that is those two wan rtrs are discontinuous which i assume they are not
Kind Regards
Paul
Muhammad Awais Khan
Your 2 LAN Router does not need to have connectivity with each other. So technically , you will be fine without any links between them. These Routes are serving the role of Area Border Routers which already have one connection to Area 2 while other connection to Area 0
Hello
Kind Regards
Paul
