OSPF IP unnumbered issue
tarnhundal
Hi All,
I am facing a issue in my network. I have point 2 point connectivity between two routers running OSPF. Now the thing is I am using ip unnumber command on serial int pointing towards fast eth int , which has IP address assigned to it. now i have one more fast eth int , I want to run different IP address on this second interface. but i am unable to ping the second int IP add from remote site, only the IP unnumbered int IP add is reachable. I am doubtful that in this scenario only one IP add is reachable not the second IP add.
Taran
9 Replies 9
lgijssel
Level 9
Level 9
Try to add a network statement for the second interface under router ospf:
example:
router ospf 1
network x.x.x.0 0.0.0.255 area y
regards,
Leo
Hi ,
I have already done this but no results.
Taran
hi taran
can you paste the configs here?
regds
thomasanthony
it got to do something related to your OSPF advertisement , check if OSPF advertise your Ethernet 2 subnets out of the router also on the remote site also try for testing - redistributing connected
tarnhundal
Hi ,
Following is the conf :
R1 :
interface Serial2/3:0
ip address 10.88.102.81 255.255.255.240
encapsulation ppp
R2 :
interface FastEthernet0/0
ip address 10.88.102.82 255.255.255.240
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.88.97.17 255.255.255.240
duplex auto
speed auto
interface Serial0/0/0
ip unnumbered FastEthernet0/0
encapsulation ppp
router ospf 1
network 10.88.97.17 0.0.0.0 area 30
  network 10.88.102.82 0.0.0.0 area 30
Please change your config as follows:
R1 :
encapsulation ppp
router ospf 1
network 10.88.102.82 0.0.0.15 area 0
R2 :
duplex auto
speed auto
duplex auto
speed auto
encapsulation ppp
router ospf 1
network 10.88.97.17 0.0.0.0 area 0
regards,
Leo
Hi Leo,
According to u , I have to put same route on both routers in OSPF. Am I right ? how this will work ? I am bit doubtful that will this situation work or not ?
taran
what is the output of following commands ?
R1:
show ip ospf int brief
show ip ospf nei
show ip route ospf
show ip route 10.88.97.17
Whenever you will configure one interface as unnumbered  and other as numbered it can create discrepancy in the Ospf Database, the only solution here is to configure either both interface numbered or unnumbered.
for more details you can read the following document:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481a.shtml#r4
