OSPF not coming up
netlinkin
I am facing problem related to OSPF
I am runing OSPF between 6 routers in area 0 with bfd support
for testing purpose i have executed shut command on one of the interface as expected teh OSPF stae changed to FULL To DOWN, but when interface made no shut interface came up ping also fine but OSPF doesn't come up still in DOWN
FYI I am using the IOS c7600s3223-advipservicesk9-mz.122-33.SRC4.bin"
Nilesh
Edison Ortiz
Make sure your MD5 authentication is up to snuff. Try removing MD5 and if OSPF comes up, re-key the MD5 string and must match - caveat on the space within the key.
__
Edison.
Tried same already but not improvement,
Can you guide further.
Nilesh
Pavel Bykov
Level 5
Level 5
1. Debug BFP
2. Try removing BFD
3. After turning on the following, do shut/no shut again.
Debug ip ospf adj
Debug ip ospf events
debug ip ospf packet
What's the state on the other side?
