OSPF not preferred over EIGRP external routes Problem
shehab320
R1 Configuration:
R1#sh run | s r e
router eigrp 10
network 10.1.12.1 0.0.0.0
network 10.1.13.1 0.0.0.0
redistribute static metric 1500 0 255 1 1500
R1#sh run | s r o
router ospf 10
redistribute static subnets
network 10.1.12.1 0.0.0.0 area 0
network 10.1.13.1 0.0.0.0 area 0
R1#
ip route 2.2.2.2 255.255.255.255 10.1.12.2
R2 Configuration:
R2#sh run | s r o
router ospf 10
network 10.1.12.2 0.0.0.0 area 0
R2#
R2#sh run | s r e
router eigrp 10
R2#
R3 configuration:
R3#sh run | s r e
router eigrp 10
network 10.1.13.3 0.0.0.0
R3#
R3#sh run | s r o
router ospf 1
network 10.1.13.3 0.0.0.0 area 0
R3#
Output from R3:
R3#sh ip route | b Ga
Gateway of last resort is not set
2.0.0.0/32 is subnetted, 1 subnets
D EX 2.2.2.2 [170/1732096] via 10.1.13.1, 00:04:09, Ethernet1/0
3.0.0.0/32 is subnetted, 1 subnets
C 3.3.3.3 is directly connected, Loopback0
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
D 10.1.12.0/24 [90/307200] via 10.1.13.1, 00:04:14, Ethernet1/0
C 10.1.13.0/24 is directly connected, Ethernet1/0
L 10.1.13.3/32 is directly connected, Ethernet1/0
R3#
R3#sh ip eigrp neighbors
EIGRP-IPv4 Neighbors for AS(10)
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 10.1.13.1 Et1/0 12 00:04:41 56 336 0 11
R3#sh ip os ne
R3#sh ip os neighbor
Neighbor ID Pri State Dead Time Address Interface
10.1.13.1 1 FULL/DR 00:00:35 10.1.13.1 Ethernet1/0
R3#
R3#sh ip os database
OSPF Router with ID (3.3.3.3) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
2.2.2.2 2.2.2.2 605 0x80000002 0x00EBFB 1
3.3.3.3 3.3.3.3 616 0x80000003 0x00C11A 1
10.1.13.1 10.1.13.1 652 0x80000006 0x004C29 2
Net Link States (Area 0)
10.1.12.1 10.1.13.1 652 0x80000002 0x00EEF7
10.1.13.1 10.1.13.1 652 0x80000002 0x0016CB
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
2.2.2.2 10.1.13.1 652 0x80000002 0x00F86C 0
R3#
Hi @shehab320
The OSPF external route will not be installed because of the following reason. If you look at the
show ip ospf database external 2.2.2.2
on R3 you will see that the forwarding address is chosen as 10.1.12.2.
R3 sees 10.1.12.0/24 is as an EIGRP internal route with AD90. OSPF external route requires that if the forwarding address on the type 5 LSA is non-zero then it should have a route to it learned via OSPF intra or inter area. You will argue that OSPF does have a route to it, but because EIGRP AD 90 is preferred over OSPF 110, OSPF route is not preferred for the forwarding address. So the parent type 5 route is not installed in the routing table.
Please rate this post and mark as resolved if you find this helpful.
Sebastian
Please run
clear ip eigrp 10 neig
and check again. If you still get the same result, please share the output of
HTH,
Meheretab
HTH,
Meheretab
Hi @shehab320
Sebastian
Thanks Sebastian, got it
Shehab
mhiyoshi
Level 3
Level 3
Hi shehab320
I think the received route is EIGRP External so AD is 170, Comparing them OSPF 110 preferd over EIGRP AD 170 right?
Do you think the routing AD preference is same specification between legacy IOS and IOS-XE?
(For example
Cat35/37/ISR-G2 and ISR1K/4K/Cat9K etc..)
Best Regards,
Masanobu Hiyoshi
