OSPF not working
Mero Cisco
HI,
I have pasted the configuration of my routers. Although the show ip osfp database shows the osfp data, it is not passing the traffic. I have given the static, the dynamic ospf routing is not wokring, What may be the problem ? The ISP 2 is working in OSFP routing but the ISP 1 is not working with OSPF.
Mero
Head Office
interface GigabitEthernet0/0
description ***** Connected To Switch  *****
ip address 10.10.0.1 255.255.255.0
ip ospf message-digest-key 1 md5 7 XXXXXXXX
ip ospf cost 10
ip ospf priority 2
duplex auto
speed auto
interface GigabitEthernet0/1
description ***** Connected To ISP 1*****
ip address 10.10.25.1 255.255.255.0
ip ospf cost 60
duplex auto
speed auto
interface GigabitEthernet0/2
description ***** CONNECTED TO ISP 2 *****
ip address 10.10.24.1 255.255.255.0
ip ospf priority 10
duplex auto
speed auto
router ospf 1
log-adjacency-changes
area 0 authentication message-digest
network 10.10.0.1 0.0.0.0 area 0
network 10.10.24.1 0.0.0.0 area 0
network 10.10.250.251 0.0.0.0 area 0
network 10.10.25.1 0.0.0.0 area 0
default-information originate
Branch Office
interface FastEthernet0/0
description ***** Connected To LAN  *****
ip address 10.10.10.100 255.255.255.0
ip ospf cost 0
ip ospf priority 2
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.25.100 255.255.255.0
ip ospf cost 60
duplex auto
speed auto
interface FastEthernet0/2
ip address 10.10.24.100 255.255.255.0
ip ospf priority 50
duplex auto
speed auto
router ospf 1
network 10.10.10.100 0.0.0.0 area 0
network 10.10.24.100 0.0.0.0 area 0
network 10.10.250.100 0.0.0.0 area 0
network 10.10.25.100 0.0.0.0 area 0
3 Accepted Solutions
Are you saying that only one ISP is being used to send/receive traffic and the other one is not??
a network diagram might help. Also, please note that yo uhave cost configured on the interfaces etc.
Higher the cost lower the preference of the link.  So, please check the metrics so maybe do a
sh ip route 10.10.10.100 on Head Office and see the cost advertised etc.
Kishore
Vivek Ganapathi
Level 4
Level 4
To my understanding, you say that you are not learning prefixes from your branch via ISP1? If thats the case, then you have to delete those cost parameters on the interface connecting to ISP1 (both sides). By that you will achieve equal cost load balancing. Incase if you just wondering why you don't see the prefixes of branch via ISP1 then to see that you need to use show ip ospf database from your head office. You would see that OSPF is aware of the prefixes via ISP1 as well. Due to the cost parameters configured on the interface, OSPF doesn't inject that bad cost route into the routing table.
Hope this clarifies.
Vivek
It should be advertised normally the way primary ip addresses are. The difference when you use routing protocols is that the source ip address for sending the routing updates ,establishing neighors and all is done using primary address. So, AFAIK neighbors are never etablished on a secondary ip address.
The whole idea of secondary ip address is to enable you to use extend your hosts range . i.e if you have a /24 subnet you can have 254 hosts in it but if you need to add another 100 then you can add another subnet under the same interface as a secondary ip address. the hosts in that will be advertised the same way the primary ip address is  as far routing updates are considered
Does this help. please ask if you need more info
Kishore
Kishore
Vivek Ganapathi
Level 4
Level 4
Vivek
Hey Guys,
Sorry, there was a mistake in conf file, i have edited it and it's working now.
Is there any solution if I have got 2,3 secondary ip in a single interface ? Please suggests if their is any kind of solution for dynamic routing for secondary ip.
Mero
Kishore
