PfR Question
Rick Morris
Level 6
Level 6
I am not familiar withPfR and looking for a solution to help control some inbound traffic without using AS-Prepending.
What I am looking to do is load share across 2 different providers.  So if I send traffic out one link it is possible based on the best path back to go across the other link.  What I am looking to do is put some sort of controls in place to help direct the traffic without saturating one link over the other from an ingress point.
Does PfR provide this functionality for not only egress but also ingress?
Any links, sample configs, docs would be great.
Rick
Edison Ortiz
This is a great starting point:
http://docwiki.cisco.com/wiki/PfR:Home
Thanks Edison, this is a good start to help with a easier to understand read versus the other "Cisco Press" type links I have been reading that are good detail but not exactly what I was looking for.
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
If I remember correctly, PfR can load balance inbound, but doing so is liable to require cooperation from your providers.  (If your doing something like PfR across a private cloud, it's better to just have both sides do egress balancing [this can also be done with OER].)
Marwan ALshawi
PfR, therefore, is configured and addresses the path selection from server to client over two or more links to typically multiple ISPs. It's also possible to load-balance on ingress using BGP.
http://docwiki.cisco.com/wiki/PfR:Solutions:InternetLoadBalancing
hope this help
