OSPF not working
Alex Hall
I have two routers connected with serial interfaces and to begin with I was unable to ping either router, anyway I want to configure OSPF 100 with the routers on area 0 the current configs are
Router 1:
Building configuration...
Current configuration : 1077 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname HQ
enable secret 5 $1$mERr$Kf7LJHoCqrlN7frh/vXzO1
enable password ttf1234
ip cef
no ipv6 cef
username ttfadmin privilege 15 secret 5 $1$mERr$sGPHml/Zec.vL6mmhKJAd0
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 10.10.10.2 255.255.255.252
ip ospf 100 area 0
interface Serial0/0/1
ip address 10.20.20.2 255.255.255.252
ip ospf 100 area 0
clock rate 64000
interface Vlan1
no ip address
shutdown
router ospf 100
log-adjacency-changes
network 10.10.10.0 0.0.0.3 area 0
network 10.20.20.0 0.0.0.3 area 0
neighbor 10.10.10.1
neighbor 10.20.20.1
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
password ttf12345
login local
end
Router 2:
Current configuration : 1044 bytes
version 12.4
hostname Adelaide
enable secret 5 $1$mERr$KZJUS7CY9GPgCalBziSwO1
enable password ttf123456
ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
ip ospf 100 area 0
duplex auto
speed auto
ip address 10.10.10.1 255.255.255.252
ip ospf 100 area 0
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 100
network 192.168.1.0 0.0.0.255 area 0
neighbor 10.20.20.2
ip classless
line con 0
line aux 0
line vty 0 4
password ttf1234567
login
end
Router 1 also has another router it's connected to but it's just a mirror of router 2, I'm not sure what I've done wrong, can someone provide some help, please excuse the ignorance I'm new to this.
Thanks in advance.
21 Replies 21
try GNS3, it is free, and uses real, full IOS images...
https://gns3.com/
Okay I'll give it a go and get back to everyone thanks
I tried it in GNS3 and it still didn't work, I have no idea where to go now, I've using two new routers and doing the config from scratch but nothing.
Hello
You have confirmed your using simulation software and the latest being GNS3 and you still dont obtain connectivity?
Now GNS3 by default uses encapsulation on its serial interfaces that requires nothing appended to it (clocking or,controller state), just the correct ip addressing and the very basic ospf1 config (below) and if this isnt working it has to be the software your using.
r1
int ser0/0/0
no shut
r2
nt ser0/0/0
no shut
both rtrs
router ospf 1
Kind Regards
Paul
Well I have to submit the lab using packet tracer, do you have any ideas as to why the config currently wouldn't be working?
Hello
It should work - Can you post the pkt file please?
Kind Regards
Paul
Sure the routers I've been talking about are HQ and Adelaide, HQ being router 1 and Adelaide being router 2 the Sydney router is going to mirror Adelaide.
