ospf redistribution E1 / E2
carl_townshend
Hi All
A quick question, If I redistribute from 2 different routers, 1 route as E2 with the default metric of 20, and then on the other router a E1 with a metric of 20, and the router that's connected to them both sees the preferred route as the E1 route with a metric of 21, is this normal behaviour? does OSPF always prefer E1 over E2 no matter even if its a higher metric ?
cheers
Jaderson Pessoa
If 2 external type 2 routes exist with the same metric to the same destination the route with the lowest metric to the ASBRwill be used. Also if an E1 and E2 route exist to the same destination the E1 route will always be preferred irrespective of the metric.
Please, Mark as solved and helpful all post that was help you.
Jaderson Pessoa
*** Rate All Helpful Responses ***
ngkin2010
Level 7
Level 7
Yes, route type always have high preference than metric.
Jaderson Pessoa
Jaderson Pessoa
Hello
@carl_townshend wrote:
Hi All
cheers
Yes it is as then cost will be irrelevant ospf path selection take precedence
(note the ospf path selection changes on ios 15.1 + releases)
pre 15.1 ios release
Intra-Area (O)
Inter-Area (O IA)
External Type 1 (E1)
External Type 2 (E2)
NSSA Type 1 (N1)
NSSA Type 2 (N2)
post 15.1 ios release
Intra-Area (O)
Inter-Area (O IA)
External Type 1 (E1) or NSSA Type 1 (N1)
External Type 2 (E2) or NSSA Type 2 (N2)
Kind Regards
Paul
Thanks this is good information but share some technical details, why the Cisco has changed?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
