OSPF redistribution
The_guroo_2
Level 2
Level 2
guys what the difference between the following two statemnets while redistirbuting connected subnets in ospf
redistribute connected subnets metric 100
redistribute connected metric 100 subnets
is there any diff or it s asame thing....cheers guys
Edison Ortiz
The IOS will parse the command and both will be identical after hitting enter.
HTH,
__
Edison.
Istvan_Rabai
Level 7
Level 7
No difference.
Cheers:
Istvan
