06-15-2020 07:00 AM
Hello
I have a router connected on the network provider router. Behind my router, I have a firewall and a switch. My router (Ge0/0/0) is connected on the provider network with OSPF configured between both routers. The interface G0/0/1 of my router is connected to my firewall. My firewall is configured with differents local networks (10.1.0.0/24 for users, 10.2.0.0/24 for servers, 10.3.0.0/24 for ToIP)
How I can configure my router to publish my local network address (10.1.0.0/24, 10.2.0.0/24, 10.3.0.0/24) to the WAN via OSPF and to apply a Tag 1000 to my network ? The provider network is configured to accept only from my router, routes with a tag value = 1000.
Do you have an exemple of configuration to be implemented on my router ?
BR
06-15-2020 07:06 AM - edited 06-15-2020 07:10 AM
Hello @Jerome C.
if all the internal routes are configured as static routes with a next-hop = FW interface IP address
Edit:
so the first requirement is a common subnet to be used between the internal LAN interface of the router and the external interface of the firewall. For example 10.5.0.0/24.
ip route 10.1.0.0 255.255.255.0 10.5.0.2
ip route 10.2.0.0 255.255.255.0 10.5.0.2
ip route 10.3.0.0 255.255.255.0 10.5.0.2
Then :
you can use a route-map to set the route tag in redistribution to the desired value:
route-map STATIC-INTO-OSPF permit 10
set tag 1000
( or set route-tag 1000 check in yout router)
router ospf 10
redistribute static subnets route-map STATIC-INTO-OSPF
You can use a prefix list as a match parameter to describe/list the internal subnets.
Hope to help
Giuseppe
06-23-2020 03:22 AM
Thank's for your help
It's working for static route but I have always an issue about a connected route. How I can redistribute in OSPF a connected route with a tag 1000?
BR
06-23-2020 03:37 AM - edited 06-23-2020 03:38 AM
Hello @Jerome C. ,
you can use redistribute connected subnets route-map CONN-INTO-OSPF
ip prefix-list SELECTED permit 10.7.100.0/24
route-map CONN-INTO-OSPF permit 10
match ip address prefix SELECTED
set tag 1000
router ospf 10
Please note that in order to redistribute a connected route into OSPF no network in command in OSPF for the subnet must exist otherwise the router will advertise the route as an internal route without a route tag.
So review your OSPF configuration for these aspects.
Final note : the network between the router and the firewall must be covered by a network in OSPF , static routes must have a next-hop that is covered by an internal route in order to be able to redistribute static routes into OSPF.
So this is the only connected route that must be kept in a network command in addition to the link to the provider.
Hope to help
Giuseppe
06-23-2020 03:52 AM
Thanks.
you will find in attach file our design. I need to redistribute 10.241.74.192/29. My current confirugation on my router (ro-mun-par-wan-a) is :
interface GigabitEthernet0/1.624
  description LAN-IF
  encapsulation dot1Q 624
  ip address 10.241.74.196 255.255.255.248
  no ip redirects
  no ip proxy-arp
  ip ospf message-digest-key 1 md5 7 080A4D6A214B1118470D2C
  ip ospf cost 10
router ospf 1
  router-id 10.241.74.49
  log-adjacency-changes detail
  area 0 authentication message-digest
  passive-interface default
  no passive-interface GigabitEthernet0/0
  no passive-interface GigabitEthernet0/1.624
  network 10.241.74.49 0.0.0.0 area 0
  network 10.241.74.120 0.0.0.7 area 0
  network 10.241.74.192 0.0.0.7 area 0
ip route 10.241.64.0 255.255.255.128 10.241.74.193
ip route 10.241.64.128 255.255.255.128 10.241.74.193
ip route 10.241.65.0 255.255.255.128 10.241.74.193
ip route 10.241.67.0 255.255.255.192 10.241.74.193
ip route 10.241.67.64 255.255.255.192 10.241.74.193
ip route 10.241.67.240 255.255.255.240 10.241.74.193
ip route 10.241.73.176 255.255.255.240 10.241.74.193
set tag 1000
It's working fine for all route execpt 10.241.74.192/29.. :(
06-23-2020 05:15 AM
Hello @Jerome C. ,
from the network diagram we see that this subnet 10.241.74.192/29 is the one used to reach the firewall and to provide the next-hop for static routes that is 10.241.74.193.
So you cannot remove this from OSPF or the static routes redistribution will fail.
However, you can do something like the following:
add a static route for a prefix less specific that includes the subnet for example:
ip route 10.241.74.128 255.255.255.128.0 10.241.74.193.
This static route should be redistributed with the desired tag and it should be accepted by the CPE
Hope to help
Giuseppe
06-23-2020 05:38 AM
I can't provide a network like 10.241.74.128 255.255.255.128 because, between 74.128 and before 74.192, the ohter address are used on other sites...
I can't change my router configuration with this :
router ospf 1
  network 10.241.74.193 0.0.0.0 area 0 --> Replace the network address by the IP of the firewall
set tag 1000
ip prefix-list SELECTED permit 10.241.74.192/29
set tag 1000
BR
06-23-2020 06:05 AM - edited 06-23-2020 06:08 AM
Hello @Jerome C. ,
if you cannot use a larger prefix with the static route there is no way to tag the route for this subnet in OSPF.
this will not work because the network command is used to find an interface on the local router that should take part in OSPF and 10.214.74.193 is not the IP address of the router but that of the firewall.
If you do this the next-hop of static routes will be an external route and no static route is injected in OSPF.because there is a consistency check on the next-hop that must be learned via an internal OSPF route.
in other words you can get the connected route advertised but you will lose all the static routes!
I am afraid you should stay with current setup.
Hope to help
Giuseppe
06-23-2020 06:20 AM
And if I try this :
ip prefix-list SELECTED permit 10.241.74.198/32
ip prefix-list SELECTED2 permit 10.241.74.195/32
set tag 1000
match ip address prefix SELECTED2
set tag 1000
router ospf 10
BR
06-23-2020 09:01 AM
Hello @Jerome C. ,
it cannot work for two reasons:
a) the connected subnet is 10.241.74.192/29 and not a collection of hosts /32.
b) the connnected subnet needs to be advertised as an internal route and will be in order to advertise the static routes.
Hope to help
Giuseppe
