Other Routers
burhaans28
Here DMVPN is working fine i can ping from hub to spoke
But from Hub to Vios I am running ospf 1
this is the config
Vios
int gig 0/0
ip add 10.11.3.1
no sh
ip ospf 1 area 0
On hub router
int gig 0/1
ip add 10.11.3.1
no sh
ip ospf 1 area 0
So i can't ping 10.11.3.1 and lo0 1.1.1.1 from spoke
but i can ping 10.11.3.2 which is on Hub router
so whats the problem
2 Accepted Solutions
Why you use ibgp between two sites?
This second post And I dont get why?
balaji.bandi
First start with IP address: (both the interface configured same IP address, so correct that one and test it)
ip add 10.11.3.1
post-show run from all device and show IP ospf neigh and show IP route information
BB
I am using ibgp because i want to demonstrate that R2 and R4 two router are my ISP and the route between hub and R2, R4 and spoke are static
balaji.bandi
ip add 10.11.3.1
BB
Router#sh run
Router#sh running-config
Building configuration...
Current configuration : 3069 bytes
! Last configuration change at 00:14:17 UTC Sun Mar 19 2023
version 15.9
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip ospf 1 area 0
interface GigabitEthernet0/0
ip address 10.11.3.1 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 1.1.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 ioam timestamp
control-plane
banner exec ^C
Hub#sh run
Current configuration : 3504 bytes
! Last configuration change at 01:01:36 UTC Sun Mar 19 2023
version 15.9
hostname Hub
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 10.10.10.10 255.255.255.255
ip ospf 1 area 0
interface Tunnel0
ip address 172.16.10.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 100
no ip split-horizon eigrp 100
ip nhrp authentication cisco
ip nhrp network-id 1
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 123
ip address 100.1.2.1 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 10.11.3.2 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
network 10.0.0.0
network 172.16.0.0
redistribute ospf 1
router ospf 1
router-id 10.10.10.10
no ip http server
ip route 0.0.0.0 0.0.0.0 100.1.2.2
ipv6 ioam timestamp
control-plane
banner exec ^C
r2#sh run
Current configuration : 3414 bytes
! Last configuration change at 01:01:55 UTC Sun Mar 19 2023
version 15.9
hostname r2
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 100.0.0.3 255.255.255.255
ip ospf 1 area 0
ip address 100.1.2.2 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 100.0.3.1 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 100.0.0.3
router bgp 1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 100.0.0.4 remote-as 1
neighbor 100.0.0.4 update-source Loopback0
address-family ipv4
network 100.0.3.0 mask 255.255.255.0
network 100.1.2.0 mask 255.255.255.0
neighbor 100.0.0.4 activate
exit-address-family
no ip http server
ip route 0.0.0.0 0.0.0.0 100.1.2.1
ipv6 ioam timestamp
control-plane
banner exec ^C
R4#sh run
*Mar 19 01:03:31.793: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 3515 bytes
! Last configuration change at 01:03:31 UTC Sun Mar 19 2023
version 15.9
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 100.0.0.4 255.255.255.255
ip ospf 1 area 0
ip address 100.0.3.2 255.255.255.0
ip ospf 1 area 0
duplex auto
speed auto
media-type rj45
ip address 101.0.0.1 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 105.0.0.1 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 100.0.0.4
router bgp 1
neighbor 100.0.0.3 remote-as 1
neighbor 100.0.0.3 update-source Loopback0
address-family ipv4
network 101.0.0.0 mask 255.255.255.0
network 105.0.0.0 mask 255.255.255.0
neighbor 100.0.0.3 activate
exit-address-family
no ip http server
ip route 101.0.0.0 255.255.255.0 101.0.0.2
ip route 105.0.0.0 255.255.255.0 105.0.0.2
ipv6 ioam timestamp
control-plane
banner exec ^C
vios9#sh
*Mar 19 01:03:37.242: %SYS-5-CONFIG_I: Configured from console by consolerun
vios9#sh running-config
Current configuration : 3470 bytes
! Last configuration change at 01:03:37 UTC Sun Mar 19 2023
version 15.9
hostname vios9
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 30.30.30.30 255.255.255.255
interface Tunnel0
ip address 172.16.10.3 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map multicast 100.1.2.1
ip nhrp map 172.16.10.1 100.1.2.1
ip nhrp nhs 172.16.10.1
tunnel key 123
ip address 105.0.0.2 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
network 30.0.0.0
network 172.16.0.0
no ip http server
ip route 0.0.0.0 0.0.0.0 105.0.0.1
ip route 10.0.0.0 255.255.255.0 Tunnel0
ipv6 ioam timestamp
control-plane
banner exec ^C
vios8#sh run
Current configuration : 3430 bytes
! Last configuration change at 01:03:12 UTC Sun Mar 19 2023
version 15.9
hostname vios8
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 25.25.25.25 255.255.255.255
interface Tunnel0
ip address 172.16.10.2 255.255.255.0
no ip redirects
ip mtu 1400
tunnel key 123
ip address 101.0.0.2 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 100
network 25.0.0.0
network 172.16.0.0
no ip http server
ip route 0.0.0.0 0.0.0.0 101.0.0.1
ipv6 ioam timestamp
control-plane
banner exec ^C
i make changes 10.11.3.1 to 10.11.3.2 now i can ing 10.11.3.2 from spoke but not 10.11.3.1
